Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Rear Suspension - Who makes this upper brace / arm?
Old Mar 28, 2012 | 10:50 AM
BOSTONCAMARO's Avatar
I have seen a couple on cars, at first thought it was a one off piece
Who makes them? how much? thanks, Tim
Attached Thumbnails Rear Suspension - Who makes this upper brace / arm?-holybajoly.jpg
Old Mar 28, 2012 | 11:20 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Rear Suspension - Who makes this upper brace / arm?
http://fays2.net/fays2_watts_link_21_.html
Old Mar 28, 2012 | 02:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i am not sure what that air damper/shock? is thats attached to the Fays2 piece on that car. Any info on that?
Old Mar 28, 2012 | 03:55 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
The Watt's link appears to be disconnected from the axle tube(s). I've never seen the damper assembly before but from the geometry it looks like it's meant to damp vertical movement. But still looking.
Old Mar 28, 2012 | 08:42 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
That looks like a cantilever (sp?) shock set up similar to what many mountain bikes have. Weird since it also has normally mounted shocks. I would love to see the rest of that car.
Old Mar 28, 2012 | 09:54 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
That's Twin Turbo's car. I'm sure he'd be happy to share photos. Be prepared to drool and be very jealous.
-Eldon
Old Mar 29, 2012 | 10:37 AM
I also saw that same set up in another car....the upper bracket thing, unless this is the same car with a different rear etc
Attached Thumbnails Rear Suspension - Who makes this upper brace / arm?-12bolt.jpg
Old Mar 29, 2012 | 10:42 AM
I don't think its the same car, but it is the same owner. IIRC, he has two cars with that setup.
Old Mar 29, 2012 | 11:19 AM
Twin_Turbo's Avatar
Yes, both are mine. The damper is a stewart shock pump, it's designed to pump rear end oil. The gold colored things are 1 way valves.
Old Mar 29, 2012 | 12:14 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I see that as the car moves up and down it'll operate the damper/pump but where exactly does it pump the oil from/to? Any idea how much it helps with lubrication?
Old Mar 29, 2012 | 03:13 PM
Twin_Turbo's Avatar
from and to the differential, it helps keep stuff cool. These things get blistering hot, especially @ high speeds.
http://youtu.be/-d1WPEGdYTA
Old Mar 29, 2012 | 07:56 PM
lb9 GTA's Avatar
Neet. Never seen one of those.
Old Mar 29, 2012 | 08:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
so it does the same thing as an electric pump for circulating the diff oil through a cooler, but its more of a mechanical setup? neat.
Old Mar 30, 2012 | 05:05 AM
Twin_Turbo's Avatar
exactly
Old Mar 30, 2012 | 12:42 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Have you ever been able to measure the oil temperature at speed with/without the pump? It's the first time I've seen a solution for something I didn't know could be an issue. Looks clever but does need vertical motion to work. Is it custom or universal fit?
Old Jun 23, 2013 | 01:32 PM
Anybody ever get an answer to this question?
Old Jun 23, 2013 | 03:46 PM
Twin_Turbo's Avatar
I have a rear end cooler on my corvette and I forgot the exact number but the pump goes on after only about a 1/4 hour of spirited driving and only runs for a short while to cool it down. I think I have it set to turn on @ 150 F or thereabout
Old Jul 7, 2013 | 04:16 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
now thats cool... i was wondering how one would pump the oil through the dif,,,, and there is the answer..
Old Jul 7, 2013 | 04:44 PM
Twin_Turbo's Avatar
You can also simply wire an electric pump and switch it with a temp switch:
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
