Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
how to repair a frame rail that helps suport the tranny mount
Old Mar 31, 2012 | 06:24 PM
corky09's Avatar
Car: 1988 camaro
Engine: 2.8 v6
Transmission: 5 speed
how could i fix a frame rail that hold the crossmember for the tranny?
on my 87 camaro the one side rails is rotted out not that bad but i wont to fix it
Old Mar 31, 2012 | 09:31 PM
ex-x-fire's Avatar
Re: how to repair a frame rail that helps suport the tranny mount
Take a couple of good pictures of it.
Old Mar 31, 2012 | 10:52 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
1/8 inch plate, make it all the way across like the u shape, weld inside and out. i had to fix where my exhaust got ripped off and took my back frame rail with it... paint both sides after to prevent rust. just have to mark where your bolts go and drill them and weld a nut inside but put the bolt in it and weld slow so you dont warp it or weld the nut to the bolt
me and all my roommate took turns standing on it and not bending, not sure how good you are as a welder but if you grind all the edges down to like a triangle shape then weld will give you a better weld, imho
Attached Thumbnails how to repair a frame rail that helps suport the tranny mount-181790_495089581556_517076556_6751790_7153781_n.jpg
Old Apr 2, 2012 | 01:43 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I drilled mine out and replaced it with one I got from a wreckers. I drilled the spot welds in the floor and frame and pulled it out and stuck the new one on and welded it again.
Old Apr 2, 2012 | 04:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'll be cutting out the back 6-8" of mine sometime in the next week, i could sell it to you if you want to make an offer, otherwise i was just going to sawzall it out and toss it. I'd have to spend a lot longer having it come out nicely.
Old Aug 24, 2012 | 12:37 PM
project87's Avatar
Car: 1987 Z28
The same thing happened to mine. It was the driver side frame rail. i got a peice of square tube (i think it was 3 1/2 sqaure with 3/16 wall) and cut it to fit, so it ended looking like a channel with one side slightly taller than the other and the whole thing tapered off towards the rear facing end. then i just cut out the bad part and welded the new piece in. You will need to be carefull welding if you still have the carpet in the car. I welded in small sections and took a 'cooling down' break often.
Old Sep 25, 2012 | 02:03 AM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
i made a weld in plate with 2 bolts welded and safety wired to the plate
Old Sep 25, 2012 | 04:24 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i'm gonna be replacing both of my stock rails with some 2X2 square tubing that run parallel with each other about 3 feet apart and make a tubular crossmember for it... like GM should have done in the first place... it will be nice to be able to run a real dual exhaust setup that has actual ground clearance..
Old Jul 21, 2017 | 10:36 AM
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
Have you done this yet? I see it's been a few day (just kidding) and was wondering how out turned out. Thanks!
Old Aug 19, 2017 | 04:45 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
can you sell it to me? or anyone out there have a decent driver frame rail to sell...
Old Aug 19, 2017 | 04:48 PM
mooch1's Avatar
Transmission: T5 WC
anyone have the driver side for sale in good shape?
Old Aug 19, 2017 | 05:44 PM
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
Here's mine
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
