Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Mono Blade Throttle Body upper plenum for HSR
Old Apr 10, 2012 | 04:38 PM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Just like the title says wondering if any one has ever done this, I would like to fabricate a sheet metal upper intake and use a 101mm mono blade throttle body on my HSR base.
any input would be awesome im currently messing around with autocad to try and do a rendering.
Old Apr 15, 2012 | 06:21 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Mono Blade Throttle Body upper plenum for HSR
My friend makes a plenum for the HSR out of carbon fiber
Custom Works Products It is about 3/4 of the way down
Old Apr 15, 2012 | 06:54 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Nope, never.. TPIS and many others have them as well.
Top is 58mm that I cut out and the bottom is a stock 48mm that I bored to 52mm then cut the center out..
Old Apr 15, 2012 | 09:48 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
$1,000! for just the plenum? Wow, you better really want that to pay that price. Nice unit though.
Old Apr 16, 2012 | 08:15 AM
markymarco's Avatar
Well the plan right now is to have a plenum made out of aluminum, and use a gm ls1 throttle body right now im stuck on using the fast 102 big mouth throttle body,
that carbon fiber plenum is awesome but 1k little out of budget.
Old Apr 23, 2012 | 12:03 PM
ks71z28's Avatar
Car: 71 z28
Engine: 383 EFI
Transmission: Tremec
Thanks james,
We have been running the CF Plenum now for a year and all has worked very well. It isn't cheap, but there is a lot that went into making the molds as well as the finished part. We have made 3 thus far.
As for the monoblade, what happens with you IAC? I guess you would need to mount it on the plenum instead. Our car makes about 450 rwhp, and don't believe the 58mm is any sort of a limiting factor, I would say after 500 rwhp you may see a drop off.
Old Apr 23, 2012 | 12:25 PM
markymarco's Avatar
As far as idle air control the ls1 tb has an iac, I plan on running a f1r procharger so I foresee a limit
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
