Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
sumped gas tank
Old Aug 12, 2012 | 09:57 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
sumped gas tank
has anyone just welded a bulk head fitting to the bottom of there gas tank instead of doing a complete sump kit? pics and advice is welcomed and wanted
Old Aug 13, 2012 | 08:58 PM
Engine: 355
Re: sumped gas tank
nobody?
Old Aug 17, 2012 | 10:53 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: sumped gas tank
sump is easily welded up onto the bottom of the tank and a much better idea.
Old Aug 18, 2012 | 01:43 PM
Engine: 355
Re: sumped gas tank
wouldnt the bulkhead be same idea as our tank is already sorta sumped with the design of the tank?
Old Aug 19, 2012 | 12:05 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: sumped gas tank
no a sump creates a small reserve of fuel in case you go around a turn or launch the car so fuel won't be uncovered ever
Old Aug 19, 2012 | 03:54 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: sumped gas tank
Anyone know if the 1le gas tank has that. I know its baffled But I dont know if it has a sump. We need a picture and part number.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
