Hood Hinge Conversion
Alright, let me just say right away that I pitched this idea to my dad and he said I was over complicating things. But, that's what I do. Anyway, Our cars all have those goofy hydraulic pistons that hold up the hood and rear hatch. My hood pistons were replaced about two years ago and they are dead already. I was wondering if anybody has replaced these with a set of good old fashioned spring-loaded hood hinges. If so, what was involved? Please take me seriously here, I know it's a petty detail, but it bugs the crap out of me.
Car: 1988 Camaro IROC T-Top
Engine: 350ci TPI
Transmission: TH-350
Axle/Gears: 4.11 Posi
Re: Hood Hinge Conversion
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Buy good quality hood struts and this won't be an issue
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i have a piece of 1/4"X2" aluminum that i leave under the hood to use as a hood prop- it's the perfect length to wedge between the fender and the bottom of the hood hinge..
yeah. it's ghetto.. but it was also free from the scrap bin at work..
Car: 1989 Trans Am GTA
Transmission: M28 T56
My hood struts are still good and they've been on the car since before I bought it nearly 10 years ago. They might not be original, but they still work just fine.
I dislike seeing thirdgen's with prop rods when the hinges aren't that expensive. I won't say anything to the owners, but its one of those basic maintenance things.
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
if you are opening and closing the hood in cold (50* range) you will shorten the life dramatically
Car: 1987 Z28 Convertible
Engine: 383
Axle/Gears: 4.11
I have a different problem related to hood struts and hinges, with a fiberglass hood the struts are too strong. I fell like I am bending the hood in half every time I shut it. The hinges are not binding. Are there "softer" struts? Or is the solution to eliminate the struts and use a prop rod.
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Keep a vise grip in your car and lock it on the strut when you need to keep the hood open. It will never let you down.
Or buy a good set of struts.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
And "vice grip" as a fix? Thats just *******.
Car: 1985 IROC-Z
Engine: 355
I got his point 100%. I know all about having a fiberglass hood. That's why they make the right struts for both applications. Get the right ones.
As for the vise grip. Try running with a built motor without being able to hold the hood open. Some times it can take a couple of weeks to get replacement parts. A vise grip is a necessity and as a mechanic, I think I use my vise grips more to hold customers hoods up in the shop more than I use them for actual work. Why? Because most people are lazy and cheap, and hood struts are not a necessity.
Car: 86 Camaro
i might try to rig in a set of G body hood hinges- they have one pivot point and should work as long as the back of the hood stays clear of the windshield.. they also allow the hood to open almost perfectly straight up if you don't use the gas struts or coil springs that the G bodies have.. for a prop, i'm thinking of making some NASCAR style hood props like these:
http://pitstopusa.com/i-6328295-alls...hood-prop.html
thought about whipping up something similar for the rear hatch, but i gave up on that after i decided to see how heavy it was without the struts hooked up.. but once i make a lexan hatch, it's getting the same thing as the hood..
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
I'm not sure what car you have , But I was thinking of the same thing With my T/A, while I was at the salvage yard the other day and looking at a fearo's front trunk, And it looks like that set up would work, As soon as I finish building my fiberglass hood I'll be looking to use that set up
Hotrodboba400
Dec 10, 2019 07:07 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
