Modded UMI crossmember for T56 swap
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Well I'm swapping my T5 for a T56 and thought I would share with yall what I did with the old crossmember. It's a UMI Performance crossmember with d/s loop and torque arm mount that I had with the T5. I wasn't thrilled with the T56 crossmember options out there and decided to hack up the UMI piece to fit the T56 and retain the d/s loop and torque arm mount. The first pic is what the xmember looked like originally.
It kinda resembles a scorpion. I think I will call it my Scorpion T56 crossmember
The tabs you see will be bolting on to one of the bolts on the Alston subframe connectors to help support the rear of the crossmember.
Re: Modded UMI crossmember for T56 swap
Here is the crossmember installed.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The support bolts to your sfc's are a very good idea, should solve the issues people have with the typical t56 crossmembers
. Even if you don't have SFC's you can still do this mod with the support bolts. Just drill a hole and run a bolt through the subframe and weld on those tabs. What problems were other cross members having? Re: Modded UMI crossmember for T56 swap
Bump TTT
I have UMI everything and would hate to use another brand TQ arm + Xmember because they don't have a version for a 1998-2002 T56. If I buy a UMI T5 TQ arm would you be willing to do this again?
Why has UMI not responded to this post
Car: Z28 Camaro
Engine: 383
Transmission: TCI Th350
Looks good! Ill save this if I ever go a t56 rout, as I also am using the UMI crossmember and arm.
Car: 87' IROC
Very cool idea. I will need to take a look at this as well. I wonder how a big rivnut (like 1/2") into the frame rail would do in that situation. I think it would serve the purpose.
Yeah I can probably do it again.
Car: 87' IROC
Wouldn't it be a lot cheaper and easier to buy the Spohn setup and slap a UMI sticker on it?
To the OP, I really like what you did. In your case it made total sense since you already had the UMI setup for the T5.
Awesome idea man. I'm trying to fab up an adjustable crossmember with mounting plates attatched to the frame and different bolt holes to slide the crossmember back for when I swap to the t56 in the furure. Do you happen to know exactly how much further back you moved it from the stock location? It would help me out a lot with my dimensions.
ambainb
Apr 25, 2016 09:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
