z34 steering wheel swap.
Car: 1992 Camaro RS
Engine: 1978 L82 355
Got a z34 steering wheel from the yard this weekend and just put it on! Really think it flows well with the theme of all the other modification I've done to the interior. That stock airbag equipped wheel is one heavy bitch!!! Has really created a lot of play in my steering column.
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Re: z34 steering wheel swap.
That looks pretty good! I like the look and feel of the airbag wheels too though, but that looks good. The play in the steering column is adjustable. It takes a fair bit of work though. The wheel, turn signal switch, ignition key cylinder, and upper portion of the column must be removed. There are 3 or 4 E-Torx bolts (size E8 i believe, and must be a 1/4" drive socket to fit in the space) that must be tightened to remove the play. They adjust the "preload" on the tilt knuckle of the column. A real pain to do, but worth it.
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
as far as wheel play there are 2 possible causes for this 1 is stated in neilbs post but there are also 2 pivot pins he didn't mention If you have cruise its a 30 second check . directly under the tilt lever theres a plastic pc that just pups off (carefully) under that there is a pin with a threaded hole in the ctr ,sometimes they wiggle out a bit ,if it did push the left side of the wheel twards the dash and tap the pin back flush with the column housing . the left side often goes bad due to using the wheel as a handle when they get out of the car. the rite side almost never backs out
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
My daily driver is a 91 z34, so I'm used to looking at it every day. Must say I approve
Car: 1992 Camaro RS
Cool, I will look into it. And yes the cap pops off. I just tugged at it till it broke lose. I've been wanting a z34 for quite awhile myself.
Car: 1992 Camaro RS
The wheel feels the same as the stock camaro one. Its a bit easier to work around with using the turn signal lever through the wheel and such. and much easier to use the horn lol.
Car: 1990 z28
Engine: 5.0
did you find the pin? was it sticking out? mine was loose and a few taps and my column is like new . hope yours is the same!
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
THe wheel looks good. I have always liked the older Z24 steering wheels.
