extended chin spoiler
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
This might not be a good idea but, I've wondered about extending the front chin spoiler an inch or so. From what I've seen, a lot of the rubbing when pulling in a parking lot or something is from the air dam underneath. I know the chin spoiler already hangs pretty low, though. Anyone tried it? I've also wondered about adding a splitter under it. thoughts, ideas....
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: extended chin spoiler
Factory design sticks out too much forward to give you any real ground clearance, less if your car is lowered. With the 70's design front wheel overhang, it's a real issue.
But if you were to put a 1" lower straight vertical front spoiler on it, that would be optimal.
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
It's been done by a member here maybe two. I know I've seen a blue iroc with a extended chin spoiler. I'll have to remember where i saw it.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I had a custom aluminum air dam (not front spoiler) that was about 2 1/2 inches longer and angled forward. It cooled the car better but rubbed a lot more. One needs to be made on a hinge that is spring loaded with a little wheel or roller that allows it roll and not grind. The factory plastic one bends.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Terrible idea for a street car.. Race only is another story.
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Front overhang is 26". My lip is 4" off the ground, which is more than plenty as long as you don't approach driveways straight on.
