Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Can someone build this for me? Name price....
Old Mar 8, 2013 | 06:23 AM
Excellegions's Avatar
Car: 91 Camaro TBI 5.0
I have a 91 camaro tbi 5.0. I have removed the elect fan and all shrouding and installed a 18" flex fan that bolts straight to the water pump pulley. It has a 3" spacer. I need someone to build me a 2 piece sheet metal or aluminum fan shroud. I want it to completely cover the radiator top and bottom so that the fan pulls air from every edge of the radiator. I can send tons of pix for whoever accepts the job. Thanks!
Old Mar 8, 2013 | 06:32 AM
Twin_Turbo's Avatar
Re: Can someone build this for me? Name price....
or you install an 82-85 plastic shroud It's 2 pc, a top and a bottom piece and it encapsulates the radiator and the fan sits in the round openimng, drawing air through the entire core.
found it
http://www.camarocentral.com/1982_19..._p/rad-79k.htm
Old Mar 8, 2013 | 02:29 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Not that Im busting your chops or anything but why did you get rid of the factory setup? Even with a stock rad. and the 400SBC mine keeps plenty cool with just the stock single fan electric setup.
Old Mar 8, 2013 | 02:47 PM
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
^^^^ya....You do know a mechanical fan robs your motor of HP and is not as efficient as a electric fan....
Old Mar 10, 2013 | 06:28 AM
I know elect fans are more efficient, there are two main reasons why I did this,
I had a 76 Camaro that had overheating issues and this technique worked, always trusted a flex fan since. Plus the hp robbed is not noticed at all, what is it 5-7 at the most? It's a sbc, tons of ways to get that hp back.
Second and most important, a lot of people hate it but I LOVE the whine sound a flex fan makes when you rev it. That in combination with my flowmaster exhuast makes me drool!! LOL
I looked at that 82 shroud, my new flex fan may come up alil higher , ill check it out. Thank!
Old Mar 10, 2013 | 12:14 PM
Twin_Turbo's Avatar
if you are using a serpentine system, you do realize the water pump turns the wrong way for a fan right???
Old Mar 10, 2013 | 05:07 PM
flash2042's Avatar
Car: 83 Z28
Engine: LG4
TT,
Could he not just grab a fan off something that came with a mechanical fan? My truck (89 1500) has a serpentine system and mechanical fan. 210 all day long. Any traffic condition, any weather. It should work, theoretically. Not that I claim to know a ton about the differences.
Old Mar 10, 2013 | 06:21 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
It creates interesting symptoms when it happens. The car is fine at idle (air is being pushed trough the rad backwards) but driving the fan stops the air from passing through the rad and the car overheats.
You can get flex fans for both directions BTW and thirdgens came in both v-belt and serpentine depending on the year (more or less)...
Old Mar 10, 2013 | 07:10 PM
Twin_Turbo's Avatar
he has a 91, 87 was the last year for the v belts w/ flat belt alt drive
Old Mar 10, 2013 | 09:19 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Reminds me of clothes pinning playing cards to the spokes of my bicycle as a kid......
I had a brand new flex fan sling apart on my 74 Hurst Olds, Took out the water pump shaft and bent both water pump and crank pulleys-all belts-cut both hoses-fan shroud and radiator..... You couldn't give me a truck load of flex fans.....
Old Mar 10, 2013 | 09:36 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
First off your fan should pull air through the radiator not push it, Your fan is turning the wrong way, thats why it gets hot sitting, I would get the correct fan.
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
