Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
rear sway bar extension question
Old Jul 30, 2013 | 08:52 AM
jpoeling's Avatar
Im swapping my 24mm rear sway bar for a 19mm rear on our autocross car. I think 19 might still be a little stiff though. Has anyone ever cut and lengthened the arms of the sway bar that go out to the end links to give more torsional pressure due to leverage. Obviously id have to move the frame mount forward as well.
Old Jul 30, 2013 | 07:51 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: rear sway bar extension question
I haven't but I know it can be done. You could also move the rear mount to the rear a lil bit..
I run the smallest rear bar I can on the rear for street action.
Old Jul 30, 2013 | 08:09 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
You can also move the axle mounts closer to the diff. It will have the same effect as a smaller bar from what I've read on here.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
