Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Head Light switch Help!!!
Old Jul 31, 2013 | 03:13 PM
MonneyMann1's Avatar
Car: 91 camaro
Transmission: T5 Manual
Hey does anyone have a head light switch retainer? Or is there another car at the junk yard that is compatiable. Thanks
Old Jul 31, 2013 | 03:27 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: Head Light switch Help!!!
Are you talking about this? http://www.ebay.com/itm/82-92-Camaro-Iroc-Z-Z28-RS-HEADLIGHT-SWITCH-screw-mount-tpi-91-90-84-90-88-86-85-/221261784796?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1990%7CModel%3ACamaro&hash=item33843ae6dc&vxp=mtr
Old Jul 31, 2013 | 03:34 PM
Car: 91 camaro
That is it. Thanks
Old Jul 31, 2013 | 03:39 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Its hard to tell from the shitty picture... but it looks like a screw from here. Whats so special about it?
Old Jul 31, 2013 | 03:41 PM
Car: 91 camaro
Damm for 21 bucks i think i will go to ace hardware and make someting work.
Engine: 5.7 TPI
It's a plastic nut/retainer that holds the headlight switch to the dash. They often crack because, well, they are old plastic original gm pieces. If your headlight switch moves back and forth as you turn your lights off/on, this is probably the culprit.
Old Jul 31, 2013 | 03:44 PM
Engine: 5.7 TPI
I bought one on ebay a few months ago for like $4, but I can't find any more available with a quick search. If I were you, I'd go to a junkyard. I'm sure any f-body 82-92 will have that same nut/retainer.
Old Jul 31, 2013 | 03:50 PM
Car: 91 camaro
Everytime i find an f-body in the junk yard its always gone already. I was able to pull off factory fog lights and the z28 grill and some other small screws and stuff. All for $33 bucks.
Old Jul 31, 2013 | 03:53 PM
Engine: 5.7 TPI
That's a good find! I know what you mean, as normally those things are destroyed when I get there the next day. If it's a TPI motor, they wreck everything else attached to it and nothing is usable. The interior is trashed and the dash is ripped apart for anything and everything salvageable.
Old Jul 31, 2013 | 08:39 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
should be the same screw as every other GM car and truckmade from the mid 60's to the early 90's with a pull out headlight switch..
BRoss99
Aug 10, 2025 05:08 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
