So I just got a working tach in. And I have an idea.
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Can someone help me modify the stock upshift light to be controllable? I no longer have the computer in the car, so it doesn't work at all, but I would like to keep my interior clean of most aftermarket gauges. Any way I can get this upshift light to work?
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: So I just got a working tach in. And I have an idea.
Some great ideas here. http://forums.nasioc.com/forums/showthread.php?t=846787
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
http://www.austinthirdgen.org/mkport...ter_pinout.jpg
Engine: 5.0
Is the 92 cluster same as the 89?
Car: 1991 Z28 Vert
Similar in that both will have a wire running from the shift icon to a pin on the connector. You can check this out too: http://www.austinthirdgen.org/mkport...uges_part3.gif
Looks like you would want the tan and black wire. :-)
Engine: 5.0
Hmm. I wonder if someone could do a picture tutorial for me. It would be much appreciated.
Car: 1991 Z28 Vert
Ok, remove your gauge cluster and take a look at the back of it and find the spot where the shift light is. Then follow that wire to the connector at the back of the gauge cluster. Then find the corresponding wire that plugs into on the car's connector. Then simply splice into the wire using any array of cheap splice connectors. You just need a controller to turn the light on now.
Engine: 5.0
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
you already have a controller on a7 of your ecm
Car: 1991 Z28 Vert
Engine: Lb9
Transmission: M20
Opps never mind than
Engine: 5.0
Well I didn't CHOOSE to go carb. Lol. Its just how it was when I bought it last year.
Terrell351
Jun 13, 2021 01:13 PM
