Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
home made chain link steering wheel
Old Feb 20, 2014 | 07:47 AM
Aus84FirebirdV6's Avatar
Car: 1984 Firebird
Engine: 2.8 V6
Transmission: 4 speed auto
hey guys, thought i'd post a few pics of this custom steering wheel i made
using about 1 meter length of 8mm stainless steel chain and an old deteriorated steering wheel from an 84 firebird
i removed the foam from it with a knife, then cut the ring off with an angle grinder, i used the inside of the ring as a template for the chain, then cable tied every 2nd link to it and welded it together on one side
its very much illegal to drive with this on where i live, but i still think its cool to switch it if i take it out to a car show n shine
let me know what you think of it
Attached Thumbnails home made chain link steering wheel-chain-wheel.jpg   home made chain link steering wheel-chain.jpg   home made chain link steering wheel-2013-07-21-15.34.59.jpg
Old Feb 20, 2014 | 08:29 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: home made chain link steering wheel
Originally Posted by Aus84FirebirdV6
hey let me know what you think of it
Well.......Glad you are happy.
Old Feb 20, 2014 | 08:45 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
while I must say the fabrication skill's are good . the wheel may be considered cool "DOWN UNDER" . here in the states (by most) it would be considered "GHETTO" . not a slam , but not for me . good fabrication as I said before , but not for me . good luck .
Old Feb 20, 2014 | 09:58 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
nice fab work.
if you plan on keeping it, i think you should get it chromed or powdercoated.
Old Feb 20, 2014 | 10:12 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Nice Work,But That's Got To Be Rough On The Hands.
Old Feb 20, 2014 | 11:01 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Looks like you put it on the wrong side of the car.......
Old Feb 20, 2014 | 11:14 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I always saw them made in about a 6" diameter....accomodated a driver wearing handcuffs.
LOW RI DER
Old Feb 20, 2014 | 05:42 PM
Car: 1984 Firebird
Engine: 2.8 V6
its really quite smooth, would be rough on the hands in the summer if its left in the sun though...
upside down because Australia
Old Feb 20, 2014 | 08:09 PM
WTR388's Avatar
Car: 87 Trans Am
Love it man.
But, then, I fully embrace the whole white trash stigma of these cars... If the military would let me, I'd grow my ****** back just for summer cruising with the t-tops out.
Old Feb 20, 2014 | 10:45 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Not my cup of tea but to each their own... Looks like you did a great job of putting it together and it always makes me do a double take when I see a right hand drive thirdgen.
Old Feb 21, 2014 | 05:18 PM
Car: 1984 Firebird
Engine: 2.8 V6
its ok guys, dont worry, i do have a wheel for it in near perfect condition
(the chain one wont actually see road use, i'd be in big trouble if the cops pulled me over)
Attached Thumbnails home made chain link steering wheel-2012-12-09-16.14.10.jpg
Old Mar 8, 2014 | 12:43 AM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
In the states, chain steering wheels are associated with low riders...why is it illegal to have it..
Old Mar 8, 2014 | 01:02 AM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Is that a right hand drive firebird ? Wtf I didn't even know they made them right hand drive
91' firebird .. 305 TBI .030 over , balanced bottom end , speed pro hyper flattops , 10.6:1 CR , all ARP rod bolts and main studs , melling HV oil pump , trick flow super 23 175cc heads, Howards HR 214/218@.050 .488/.495 lift on 114 LSA , full roller 1.6 RR = .520/.528 lift , summit dual plane intake port matched , shorty headers into 2.5" Y w full 3" flow master system and 3" cutout in front of axle , msd billet dizzy, 620cfm TBI , custom CAI , tubular adjustabke LCA pan hard , umi torque arm wonder bar , BMR trans cross member , COMP engineering SFC's, disc rear w 4.10's, drilled an slotted rotors, EBL flash , VRFPR, WBO2,
Old Mar 11, 2014 | 09:57 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
they are conversions done for countries who need Right hand drive vehicles
as far as i have ever read, the "stock" conversions done in the 80's and 90's were poorly executed, most enthusiast nowadays do their own conversions or have shops do it professionally for better results
BlueIroc-Z
Jun 9, 2019 03:22 AM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
