Making up brake lines for 12 bolt - need pics of stock
Hi I am making up lines for Kirby's 12 bolt and I need pics of where the main steel brake line goes into the bracket inside the drivers wheelhouse, how it then attaches to the rubber hose and where it goes to the rear end housing to meet the steel hard lines coming from either side of the axle. We want to have a set up similar to original.
We are also wondering if where the rubber line comes off the steel line in the rear driver side wheelhouse, is there another brake line that goes inline before getting to the rubber/brass hose assembly that mounts to the rear end, or is the hose coming off the rear end, go directly to the steel line in the rear driver side wheelhouse
Any and all pictures would be very helpful to show both close ups and further away perspectives..thanks in advance!
