Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
A different battery disconnect switch location
Old Apr 24, 2014 | 06:32 AM
drunkenmonke's Avatar
Car: 1985 IROC-Z
I searched for hours on this and other sites and really only came up with a few options that I wasn't really crazy about so I figured I'd share what I did for my mine. Most of the switches I saw were installed high behind the license plate and the plate wouldn't fully close. Others were in the taillights and I didn't want to drill into them or the bumper. Some had to cut their interior plastic because the switch stuck out.
So I drilled just center below the key hole and it fits fine. My plate closes fully and interior fits over it without having to cut it. The only extra fabrication was that I had to cut a small piece of metal above the switch to get it to fit. The metal that I cut out doesnt affect the integrity of the hatch lock, and the switch sticks out just as far as the hatch locking mechanism. Let me know what you think.
Attached Thumbnails A different battery disconnect switch location-1.jpg   A different battery disconnect switch location-2.jpg   A different battery disconnect switch location-3.jpg
Old Apr 24, 2014 | 09:15 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: A different battery disconnect switch location
that looks like a pretty clean installation. nice idea!
Old Apr 24, 2014 | 11:57 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I used a resettable breaker but you have to lift the trunk lid to get to it. It is more of a theft deterant and safety (fire) feature than anything else. It is on top of the battery which is in the trunk on the passenger side. I used the umi battery box and bolted it to the frame where the spare tire used to be.
Old Apr 24, 2014 | 05:25 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Thats exactly where I put mine. Plate closes just fine too. I did have to trim up the plastic piece though because I did not like how I needed to route the cable to the battery. Wanted to keep it short.
Old Apr 26, 2014 | 10:57 PM
oil pan 4's Avatar
Car: 89 Firebird
I put one of those where the ash tray was.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
