Has anyone modified the 82-84 cowl induction to work with EFI?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Just curious if anyone has tried using the cowl-induction set up from the 82-84 Firebirds to work with/be an additional cold air add to an EFI system?
Car: 1983 Z28
Engine: 385 Fastburn
Re: Has anyone modified the 82-84 cowl induction to work with EFI?
You talking about the crossfire flaps?
If so, then I know it's been done, read about it on here somewhere. I almost did the same thing on my car (except it's carb'd) but the stock hood wouldn't fit.
Car: 1984 Trans Am
Not sure if it's called the cross fire "flaps" or not, but the cowl piece that is above the carb and mounts to the power bulge. It opens at 75% throttle to allow more air into the motor.
Car: 1983 Z28
Wow, totally didn't read that you were referring to firebirds.
Just ignore my entire other post lol.
Car: 1984 Trans Am
If you're talking about working with a crossfire car they came that way from the factory, the scoop just got a different shaped gasket/opening (bigger than the carb one, sort of diamond shaped).
I'm pretty sure that I have one in the garage...
Car: 1984 Trans Am
I'm considering going to Fuel injection (miniram), and am trying to figure out if there is a way i can make the cowl induction part still useable. A little extra "Air" coming in at 75% throttle if nothing else.
If I can't figure it out, I'm going to just leave the set up in place because it's perfectly fine where it is and won't hurt anything.
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
My 84 has a CCQjet and the cowl induction set up on the hood that is still functional.
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Besides directing that air flow, you will also need a micro-switch, a relay, and some wiring. You can fab up a bracket to mount the switch so the throttle linkage pushes the switch. That in turn would make up the coil of the relay which would then pass the required 12v through the load side of the relay and power up the flap solenoid. Piece of cake.
Car: 1984 Trans Am
ElPaleterro85
Aug 13, 2015 03:49 PM
