Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Full 4th Gen Swap
Old Mar 25, 2015 | 11:54 PM
DukecityWarrior's Avatar
Car: 1987 Trans Am
Engine: TPI 5.0L
Full 4th Gen Swap
Hello, I have recently acquired a 94' LT1 T56 T/A and I am planning on putting the engine/trans/rear in my 87' T/A after this conversion I'm planning on doing a 4th gen dash swap.
My question is how does the wiring come into play between harnesses on the car, engine, ECM, interior? Would most of it be "plug and play"?
I'm thinking of doing custom 4th gen door panels as well so I would have switches in the door, and mentally attempting to have full functioning heat and AC. I know stock camaro/firebird LT1 has issues with position of AC compressor. Anyone have success using corvette LT1 AC bracket?
Anyone have experience in full conversions? Any tips or advice would be appreciated.
Old Mar 28, 2015 | 12:59 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Full 4th Gen Swap
Start with the "stickies" and threads here.
https://www.thirdgen.org/forums/ltx-lsx/
Old Apr 1, 2015 | 05:29 AM
Gecz28's Avatar
Car: 88 iroc vert
im doing the full swap from a 98 z, engine, trans, rear, wheels, tank, all wiring, interior, heat/ac, c5 brakes. i just got to finish the heat/ac and door panels
Old Apr 4, 2015 | 02:39 PM
Car: 1987 Trans Am
Engine: TPI 5.0L
That is going to be a sick ride when it's done. How much time do you think you have into it?
Did you take everything that was stock out and essentially start over?
Did you use 4th gen fuel tank as well?
Old Apr 4, 2015 | 05:43 PM
Gecz28's Avatar
Car: 88 iroc vert
ive been working on the car for about 6 years lol
basically i did strip the both cars. i did have to modify the tank neck(mine is 98 which is metal)
so far a few things i had to modify where k member for a/c and oil pan, gas tank neck, shifter cable hole, cut a few tabs for dash, brake and fuel lines, and custom/modify door panels
Old Apr 4, 2015 | 07:01 PM
Car: 1987 Trans Am
Engine: TPI 5.0L
When it comes to the dash, I know you have to some modding but how close does it line up?
I'm going to assume you put the 4th gen dash vents in? If so how difficult was that part? You put in 4th gen heater box as well?
What route are you deciding to go with the door panels? I was thinking to modify with fiberglass.
Old Apr 4, 2015 | 08:12 PM
Gecz28's Avatar
Car: 88 iroc vert
theres about 1" gap on each side.
i havent done anything with the vents yet.
im modifying the 4th gen panels to fit the 3rd gen door then leather wrap them
Old May 8, 2015 | 12:14 AM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
https://www.thirdgen.org/forums/inte...r-ducting.html
Everything you need to know to have fully functional 4th gen dash vents.
Old May 19, 2015 | 06:17 AM
DillonRager's Avatar
I also have a 94 lt1 t56 car as a donor... and want to do almost the same thing sounds like. subscribing
Old Jun 7, 2015 | 12:55 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Fell free to check out my thread in the sig ive done everything everybody is talking about in this thread full interior, wiring, engine/trans, rear end, a/c, fuel, and tons of other little mods
Old Jun 7, 2015 | 12:59 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
midge54
Dec 27, 2019 04:14 PM
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
