Fog lights bracket?
Car: 92 RS Camaro
Engine: 3.1L V6
Transmission: Manual 5 speed
Fog lights bracket?
Alright so I'm buying a bow tie grill for my 92 Camaro and I don't have the original fog lights I was wondering if anyone had any experience in aftermarket fog light and if so how hard was it to fab up brackets for
Car: 1989 Firebird Trans Am
Engine: 355
Re: Fog lights bracket?
Should be really easy if you have a welder/ cut off wheel. Make the bracket, drill some screw holes, attach light, attach bracket and light to car.
Car: 92 RS Camaro
Engine: 3.1L V6
Engine: 355
No, unfortunately. I'm looking to do the headlight pop up delete now and I have to use two small fog lights, and two small driving lights for short and long distance beam. But I haven't bought anything yet. I'll let you know if I see anything
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
Do yourself a favor and spend some money on a set of good LED fog/driving lights. I have a set of Rigid's in my Jeep and they are amazing. If i ever get my IROC back on the road i am planning to run a full LED light setup on it...front and rear.
Car: 1989 IROC-Z, 1970 Camaro SS
Engine: 5.7
I bought these from Walmart. Don't use them much but have had no problems with them so far.
http://www.walmart.com/ip/Optronics-...t-Kit/16680054
Car: 1988 IROC-Z
These are the lights i am running in place of the OEM fog lights on my 2000 Jeep Cherokee:
I did take the end caps apart and caulk them to try to keep out as much moisture as possible, but for $31.10 shipped they'll blow any halogen light out of the water.
