Brake hubs
Car: 1987 Trans Am
Brake hubs
Has anyone fabbed their own brake hubs around here. I know about machining down a set of rotors, or buying some from KORE3 etc.
Say I didn't want to run wheel spacers and needed to space the hubs out .400", anyone done anything like this? I would be using 7075-T6.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Brake hubs
So you are going to machine your own hubs? If you have the equipment go for it. If not use cut down 1le rotor/hubs and slip on rotors and that will get your wheels out the .4 or so you need. Just have to alter the brake caliper brackets to accomidate the change as well.
Car: 86 Trans Am
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Brake hubs
find a set of old worn out rotors and measure them... G bodies and 2wd S10 trucks use the same rotors..
dbrochard
Sep 19, 2015 08:13 PM
