Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Firebird Project Update
Old Oct 19, 2015 | 04:59 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi Guys,
I'm going to stop working on the Firebird for the summer and just thought I would post a few pictures of my latest progress...
-Installed 4th gen battery mount/radiator overflow tank
-Installed 4th gen windshield washer (see blue cap in pic)
-Made a new lower-radiator support so Champion radiator to fit
-Made a simply radiator hold-down with electric fan mounts
-Made a non-AC fan blower mount/cover
-Relocated battery and associated wiring to passenger side
-Added an aftermarket transmission cooler
-Added 36# Bosch 3 injectors
-Removed factory steering shaft and replaced with one from an S10
-Covered factory overflow & windshield washer tank holes
-Painted engine bay, bolts, etc
-Made a true dual, 3" exhaust
-Replaced entire suspension, springs, steering (except steering column) and steering box
-Started tuning and got her to idle pretty good. More tuning next summer
*Note - the cone air filter is only temporary until I fab up something. Also, the driver side muffler has a slight tilt i need to fix.
Previous updates, including engine details, are in my signature.
This project was my first time using fiberglass and welding, so have pity on my limited skills
Thanks guys!
Attached Thumbnails Firebird Project Update-engine1.jpg   Firebird Project Update-engine2.jpg   Firebird Project Update-engine3.jpg   Firebird Project Update-exhaust1.jpg   Firebird Project Update-exhaust2.jpg
Old Oct 22, 2015 | 11:24 AM
WTR388's Avatar
Car: 87 Trans Am
Re: Firebird Project Update
What was involved in the S-10 steering shaft swap?
I have an Astro shaft that I haven't installed yet, so if the S-10 is easier I'll grab one
Old Oct 22, 2015 | 12:06 PM
cruisen89rs's Avatar
Car: 89 camaro rs
Engine: 305 4 barrel
Transmission: auto 700r4
Axle/Gears: stock 10 bolt
Hey guys just wondering how much better is a s10 shafts from the stock what could I gain from this mods sorry it's just seen that and I'm all about steering mods
Old Oct 22, 2015 | 08:33 PM
WTR388's Avatar
Car: 87 Trans Am
It's just like doing the Astro or jeep shaft, gets rid of the rag joint (sloppy) and replaces it with a shaft that uses a u-joint set up for a more direct feel. For the Astro shaft you take the shaft apart, clock it 90 degrees, tack it back together and then when you install it on the steering shaft on the car, you have to notch the shaft on the car for the bolt to pass through.
Old Oct 22, 2015 | 08:44 PM
Car: 89 camaro rs
Oh that's awsome! Thanks for the info..also I purchase a unbalanced engineering rag joint eliminator I've heard great things about it can't wait to see the difference
Old Oct 25, 2015 | 05:54 PM
Sorry for getting back to you so late. I can't recall if I had to notch anything... but it was a really straight-forward swap. Actually a lot easier than I thought it would be.
IROCThe5.7L
Oct 29, 2001 01:21 PM
FiReBReTHa
Oct 10, 2001 09:52 AM
camaro 22
Apr 23, 2001 07:24 AM
FiReBReTHa
Mar 13, 2001 03:02 AM
FiReBReTHa
Aftermarket Product Review
Mar 11, 2001 08:02 AM
