Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Floor Pan
Old Dec 21, 2015 | 05:23 AM
Slayze's Avatar
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
Floor Pan
I need to replace my driver side front floor pan. Ones I see offered are a full left/right side and they aren't cheap. Is there anyone who sells just the front left side only instead of the full left side?
Old Dec 21, 2015 | 08:44 PM
WTR388's Avatar
Car: 87 Trans Am
Re: Floor Pan
I think it's all or nothin
Old Dec 22, 2015 | 07:36 AM
Mikeo91's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Re: Floor Pan
I had the same issue. Had to buy a full drivers side and only used the front. See if you can find somebody local that carries them, shipping is almost as much as the pan. I lucked out and found a guy about 20 miles from home that had them for $200.
Old Jan 6, 2016 | 07:43 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
Re: Floor Pan
I'm putting 4th gen floor pans in my car. the entire thing. Once done I will use 4the gen carpet. Not much of a difference between the two, so far all is installed except front drives side but is cut and ready to weld in, it just got cold. Got the whole thing from junk yard for $100
Old Jan 8, 2016 | 08:14 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Floor Pan
How much is not cheap?
-- Joe
Bob88GTA
Dec 22, 2015 06:07 PM
Simon Wu
Dec 22, 2015 07:46 AM
I_R_O_C_Z_2_8
Dec 21, 2015 05:53 PM
Bob88GTA
Interior Parts Wanted
Dec 20, 2015 07:12 PM
johnbhm
Brakes
Dec 15, 2015 08:15 PM
