Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cross Brace
Old Dec 31, 2015 | 03:04 PM
Z28/ZR1's Avatar
Cross Brace
Due to the limited space between hood and Stealth Ram. Made of 304 Stainless which polishes up to a chrome finish, plus much harder than plain steel. Attached to both shock towers and firewall cowl in order to limit any flexing.
Old Dec 31, 2015 | 04:53 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Re: Cross Brace
A looks great! Stock hood?
Old Dec 31, 2015 | 05:05 PM
Z28/ZR1's Avatar
Re: Cross Brace
Thanks. Yes, stock hood.
Old Dec 31, 2015 | 05:36 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Cross Brace
It looks nicely done. However, the single bar at each end will likely flex enough to limit the effectiveness.
Old Dec 31, 2015 | 05:51 PM
Z28/ZR1's Avatar
Re: Cross Brace
Stainless 304 is much stronger than reg. steel. Also used 3/8" plate stainless 304 for brackets. It's not the ideal brace, but under the circumstances it will perform fairly well.
Old Dec 31, 2015 | 06:37 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Cross Brace
Nicely done.
Old Jan 1, 2016 | 09:32 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Cross Brace
Nice fab work,....... I hope that it works for you as well as it looks !!
Old Jan 1, 2016 | 12:14 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Cross Brace
, but
robguitargod1
Mar 4, 2016 09:08 PM
codyscamaroz28
Exterior Parts Wanted
Jan 12, 2016 08:19 PM
Ard
Dec 29, 2015 06:38 PM
Strick1
Dec 11, 2015 12:43 PM
