Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom gauge pod
Old Jun 17, 2016 | 07:55 PM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Custom gauge pod
I seen someone made something like this on here quite some time ago so i thought id give it a shot. Not too bad sofar in my opinion, just gotta finish up some sanding and paint it
Old Jun 17, 2016 | 08:22 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Re: Custom gauge pod
That looks pretty good. How did you make that?
Old Jun 17, 2016 | 08:49 PM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
i ordered a first gen camaro gauge pod on ebay mabe by autometer, the angle on them is great, i cut it in half with a dremel and cut the ashtray out of my conshole and sanded the edges of the pod until it was damn near an exact fit, glued it together with a two stage plastic apoxi and filled all the crevises with glasing putty
This was the start
Old Jun 21, 2016 | 01:54 PM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
finially finished! Took about a month of my lunch brakes at work but its done!
Old Jun 21, 2016 | 02:01 PM
Crashbandit63's Avatar
Car: 1989 Iroc-z convertible
Engine: lb9
Transmission: auto
nice! that came out awesome
Old Jun 21, 2016 | 02:08 PM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Thank you! Cant wait to get it installed, just gotta get my flywheel back from the speed shop thats balancing it and get the trans back in and see how it looks
Old Jun 21, 2016 | 02:13 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Very nice job. Too bad I can't do that with my T/A. Did you get that shift boot from Redlinegoods?
Old Jun 21, 2016 | 02:17 PM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
thank you! I got the shift boot on ebay for $24 and its real leather!
https://www.ebay.com/itm/181927499324
Thats the one that i got they have all different color stitching
Old Jun 21, 2016 | 02:57 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
That turned out well!
Old Jun 21, 2016 | 05:51 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
That's bad ***!
Old Jul 13, 2016 | 12:20 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Great job. Can't wait to see it in the car.
Old Jul 13, 2016 | 02:10 PM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Thank you! It will be in soon, car is kind of at a stand still at the moment, started a little project with it that i ran out of money to finish but it will be going again asap
Old Jul 13, 2016 | 02:58 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I've got this same problem. Stuck on the Camaro and my Mercedes.
Old Jul 14, 2016 | 08:15 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Sweet and nice work. Thanks for sharing.
What would you do differently now that you have it complete?
Old Aug 23, 2016 | 09:03 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Love it! What are you going to do with the other 2 pods? What epoxy did you use? I'll be completely ripping you off btw!
Old Aug 23, 2016 | 11:44 AM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
i dont think id do anything differently, im verry happy with the way it came out, i like the way it looks in the car
And the other two gauge pods are long gone, i messed them up my first try to get the cut to line up with the console where my ashtray was, second attempt went well haha, i used a sandable 2 part epoxi the brand is conserve, i dont know where to buy it, i got it from a bodyshop i use to work for they kept it in bulk, sanded that smooth and then a very thin layer of bondo ontop of the seme to sand that down smooth like glass then prime wet sand ofcourse and paint
Ill post some better pics of the gauges lit up soon, i finially got my stealthram and i gotta put my new harness in so i can get some power back to the inside of the car to finish wiring the gauges in then a tune and it will finially be running again! Its only been about 5 months but it feels like forever
Old Aug 23, 2016 | 03:05 PM
ThirdGen1984's Avatar
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
looks great
Old Feb 22, 2017 | 06:16 PM
Car: '91 LS6/T56/9"
Engine: LS6
Could you give some details about the products and procedures you used? Fairly high level. I'm guessing something like this:
1. Cut gauge pod and shifter bezel to fit together.
2. Use epoxy to adhere the two together (what kind did you use?)
3. Sand semi-smooth
4. Apply filler (what kind??) and sand smooth
5. Paint
I'm really just curious about how you adhered the two together and what filler you used? I'm pretty good with bodywork, just never modified plastics yet.
Old Feb 22, 2017 | 09:03 PM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Thats the epoxy, i got it from my old job, its sandandable and adheres great, i super glued the pod to the conshole first tho, then went over the cracks with the epoxi sanded it down and went over everything again with bondo sanded that smooth and sprayed the whole thing with high build primer wet sanded it with 600 then 800 then 1000 and painted it satin black finially, i have yet to finish my car so i still have no pictures of the gauges up and running
Old Feb 26, 2017 | 05:39 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Looks great!
spurgeon76
Feb 17, 2025 04:49 PM
Mattkovitch
Jun 16, 2016 04:52 PM
86IROC112
Jun 15, 2016 11:46 PM
moneyman380
Jun 11, 2016 10:26 PM
mrestrictrplate
Jun 5, 2016 03:18 PM
