sticking neck out/poor man's tub & narrow
#51
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: sticking neck out/poor man's tub & narrow
Is the passenger side panhard mount in the way of the tire?
#52
I'm not saying the control arm doesn't need work, my car is minutubbed and I has SPOHN build be a set of custom offset control arms to clear the wheel and tire. However the shock mount is still in the stock location and has plenty if clearance to everything. I know you shortened the axle a lot and now the brackets are un different places, but I don't see why you wouldn't be able to put a new mount on the axle for the shock and use to factory top mount hole.
I think i might have seen pics of your control arms a while back? we're they black, square tube? IIRC, they came out real nice.
yes, the panhard mount is going to get moved in also. i'll probably make my own adjustable bar? it doesnt look that complicated.
#53
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just need some large LH and RH thread tap and dies
#54
Car: 91 Firebird
Engine: 6.0
It is coming along really well.
You definitely have the skill to do this project!
#58
decided to cut apart some of the floor to gain access for better welding to the control arm mounts.
been so long that they got rusty, lol.
welded in the top and bottom, then paint before closing the hole.
some stitch welds and called it a day.
looking forward to making some progress in the near future. bought a wheel tub kit from summit too. its collecting dust.
#61
another shot of the difference from stock location.
added a little filler piece to the corogated inside frame part. i'll be bracing from there to the shock mount area before cutting the outside frame area.
drilled a hole straight up from the center on the coilspring mount. this is where i plan to cut for the edge of the tub. the screwdriver is where the hole came through.
#64
That's going to be a good sized tub, should have tons of room for tire.
I may have missed it but are you moving the pan hard mounts?
#65
yes, moving the mounts. the passenger mount is definetly in the way.
heres the tub kit i bought. i've never tubbed a car, so this is all new to me.
https://www.summitracing.com/parts/sum-g7908
hoping to get some more time to work on it this week. unfortunatly an emergency job came up today,so i got nothing done on the 'maro.
#66
I'm feeling confident that it will have plenty of strength now. really thought oval pipe/tubing added a nice touch from the shock mount to the hoop area. went with a few different size pipes to break it up a bit. used a crappy flux-mig inside the frame rail since nobody will ever see it after its boxed. i'm going to add a few filler plates up top around the pipe. i'll TIG what can be seen.
#72
thanks!
yes, i've had to sharpen the tungsten MANY times unfortunetly. kinda frustrating. i bought 2 more pieces so i can change them when the tip gets bad, then sharpen them all at once.
the machine isnt bad for thicker material, but tricky on thin stuff with no pedal, on/off switch, or high frequency start. kinda wish i would have bought a better machine, but this one has paid for itself a few times already with side work.
#73
just a little update as i've had some time to mess with it. ran into another issue, (remember i've never tubbed a car before). i put the inner tub in place and noticed the rear opening in the hatch area is flat, from about the center back.
not easily seen in this pic.
but in this pic you might be able to notice? the green line is the axle center line.
really hi-tech drawing showing the issue in yellow.
#74
so i made a filler piece. it has a small radius at the back for the gas tank fill.
then welded it in. now the outside lip of the tub will have somewhere to land.
started adding some patch panels.
rear area
front
rear area
front
#75
25 year exp welder. That explains how you got such beautiful welds from a cheap
HF tig welder. I'm impressed. It just goes to show that the best equipment does not mean S*** if the operator has no experience. Great job.
I think you should have run a bead where the axle tubes meet the center section, though.
BTW, I got a call back from Auburn Gear today. I asked what was the weak link in a 7.5" rear, because I thought about upgrading to 28 spline axles. They told me that the weak link was the small side gears in the differential, and the small 10 tooth pinion (I have 4.10s).
So, you already know this, but all of this work is only going to help explode your 10 bolt faster. Damn impressive fabrication skills, though.
#76
thank you. i sort of wish i would have run a bead around the axle tubes, but thought it might warp beyond control? i guess i still can. i'm in no hurry, just a project.
i've been running 3.73 gear on a 2 series carrier. kinda hoping the thicker gear set will hold up better?
as luck would have it, a buddy gave me a 9". it will need work of course. i guess i'll mess with that after the tub job is done?
#77
still plating/boxing the frame area in little by little. some areas i was able to weld on the back side also. i used a big piece of glass to true my cuts up before welding in any plates.
not worried about pretty as the tub will cover most work. just want it strong and true.
basically been cutting pieces of cardboard to fit, then transfer to sheetmetal when the pattern fits.
so how wide of a tire can i ran after all this crazy work might be the question? i took this pic the other day looking straight down, from frame area to outside of wheel opening.
#78
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
#79
Good to know. Thanks. My 334 SBC will not exceed those numbers.
#80
Car: 86 Z-28
looking good!
#82
so i finally got a wheel tub temporarily mocked up after all this time.
started by taping a few strings across from side to side.
made another cardboard template, then transfered it to the metal after it fit.
marked every 2" around the radius, then measured to the wheel opening and wrote every measurement down.
another cardboard template to test fit.
#83
then one of my sons helped me with assembling the tub/pittsburgh seam. it had to go in from underneath. we set it in place for another test fit and i got a few pics. i've got to pull it back out for some minor trimming, but thought it looked ok.
the gap pulls in tight. its just lightly sitting there.
#87
No major updates. I am curious to see how the bearings do also and if it rides nice and smooth.
i did some finish trimming on the tub. then bought some 3m, 5200 marine grade caulk for final install. if anybody else has used this stuff before, i'm sure they can testify how strong it is. i basically thru-bolted the tub it.
#88
went back over all the seams.
started brush painting the bare metal with some gloss black rustoleum since everything kept getting surface rust behind me. unfortunatly i used some old paint i had laying around and i think it looks horrible. i'll probably lightly sand it and put another coat on of a fresh can i bought. then move on to the other side. been very busy with other projects, life, work, etc, all the un-important, non-3rd gen related things.
took a measurement from control arm to out side of body. kinda wish i would have took this measurement before i started to see how much i gained.
#89
Back from the dead. Actually life happened and i had to move the camaro in the middle of all this work.
#91
i was gonna add some pics but my photobucket account got locked for money. i'll figure out how to add pics again eventually.
i have managed to pic up and assemble some parts in the past few months. went with a set of sportsman pro, 29x15.5x15's. they fit perfect. got an adjustable panhard bar. put a true trac in the rear with an aluminum cover with the carrier cap braces. have finished some welding on the passenger side. working on moving the sway bar mounts and narrowing the bar itself. got some different coilovers, etc. can't wait til its done.
#93
yea, thats what my daughter suggested. i'm horrible at computer skills. guess i need to get some lessons.
#94
Havent been on here in a long time, but wanted to follow up. I put a true-trac carrier in the 10-bolt. Its still going strong.
427seven (12-17-2019)
#96
Put a lil 142 weiand supercharger on it. Its just a street car. Only go to the track like once a year. Personal best is a 7.2 in the 1/8 so far.
#98
Thanks for looking & i hope this somehow helped somebody. If/when it breaks, i'll post back
