Fuel pump in the spare tire compartment
I bought a Magnafuel Prostar 500 pump.
I'd like to install it in the spare tire compartment.
I'd place it on the bottom of the compartment so as to be close to the fuel level.
Anyone did this?
Pics?
What did your bulkhead look like?
Anyone did this?
Pics?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Fuel pump in the spare tire compartment
You wouldn't be allowed on a track since the fuel pump would be considered in the drivers compartment. You would need to fabricate some sort of firewall to isolate it from the drivers compartment. The plastic covers do not qualify as a firewall.
If you don't intend on going to any track, you can mount it anywhere you want.
Car: 87 IROC L98
Sealed on all sides would probably pass. Depends on what your tech person thinks of it.
Unfortunately I don't. However it's pretty similar to what this guy did in his write-up: https://www.thirdgen.org/forums/carb...tric-fuel.html
If you're wanting to run the single 4" over the driver side though I don't think it would work. If you're running it over the passenger side then you shouldn't have any issues.
