Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Help wiring 220v 1phase reversing switch
Old Jun 2, 2017 | 04:57 PM
rgauder's Avatar
Car: 1987 Trans Am
I have a 220v reversible motor and need help wiring it to a fwd/reverse switch. The motor can be wired to run in reverse.
Attached Thumbnails Help wiring 220v 1phase reversing switch-motor-1.jpg   Help wiring 220v 1phase reversing switch-motor-2.jpg
Old Jun 2, 2017 | 04:59 PM
rgauder's Avatar
Car: 1987 Trans Am
Re: Help wiring 220v 1phase reversing switch
Will this work, even though I'm missing T2, and T3?
Attached Thumbnails Help wiring 220v 1phase reversing switch-2014-08-09_150748_horse_walker_motor_and_4uye9_drum.jpg
Old Jun 2, 2017 | 08:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
A typical single phase motor can be reversed by switching leads 5 and 8. This can be done with a simple "4 way" toggle switch.
Old Jun 2, 2017 | 09:18 PM
rgauder's Avatar
Car: 1987 Trans Am
I didn't think that the toggle switches were rated for a 3hp motor?
Old Jun 2, 2017 | 10:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Go to your local Princess Auto at 3575 Forest Glade Dr and buy SKU: 8078693
Old Jun 3, 2017 | 08:24 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
They are not, but you didn't mention the size of the motor earlier
That motor should draw in the neighborhood of 17amps. In a pinch a 20amp 4 way would work for most applications albeit borderline on the amperage rating.
Old Jun 3, 2017 | 08:44 AM
rgauder's Avatar
Car: 1987 Trans Am
Awesome, didn't know they would have the drum switch there. My only question is will this work, even though I'm missing T2, and T3?
Is it assumed that T2 and T3 are already connected to T1 and T4?
Thanks for the help so far.
Once I get this wired up, I can start turning thirdgen parts on my lathe.
Old Jun 3, 2017 | 09:30 AM
rgauder's Avatar
Car: 1987 Trans Am
I was stuck on using the other style of drum switch that is supposed to be for 1phase, but this looks like the 3phase version will suit my needs.
Attached Thumbnails Help wiring 220v 1phase reversing switch-reversing-switch.jpg
Old Jun 6, 2017 | 08:01 AM
rgauder's Avatar
Car: 1987 Trans Am
I have to modify the mount on the machine for this motor, but I think I'm gonna try this drum switch wiring. It appears to do everything according to the motor diagram.
It switches T5 and T8. P1 connects to L1 in both directions. T4 is always connected to L2. T1 is always powerless.
Old Jun 6, 2017 | 06:18 PM
rgauder's Avatar
Car: 1987 Trans Am
It works. T5 and T8 need to be switched at the switch so that forward is forward and reverse is reverse, but it works. Need to line up the motor with the pulley tomorrow and we're in business.
Old Jun 12, 2017 | 02:08 PM
rgauder's Avatar
Car: 1987 Trans Am
Ran out of bandsaw blades today halfway through cutting some aluminum stock for gauge bezels. Did get a 1LE disc brake rotor turned into a hub though.
Attached Thumbnails Help wiring 220v 1phase reversing switch-hub1.jpg   Help wiring 220v 1phase reversing switch-hub2.jpg
