Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Gas Spewing out of the Fuel Tank Ventilator Valve.
Old Jul 25, 2017 | 02:30 AM
91GTABIRD305's Avatar
Car: 1991 Pontiac Firebird Trans Am GTA
Engine: 5.0 TPI
Transmission: 4 Speed Automatic
I recently installed a new fuel pump. The fuel pump is now running except theres one problem. All the gas spews out of the Ventilator Valve. All the lines are where they should be. Could it be a backed up fuel line. Please drop your thoughts. Thank you very much.
-Matt
Old Jul 25, 2017 | 05:02 AM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Re: Gas Spewing out of the Fuel Tank Ventilator Valve.
Did you drop the tank or just do a trap door? Absolutely sure the lines go where they should? Is gas even making it to the engine?
Old Jul 25, 2017 | 09:26 AM
Engine: 5.0 TPI
lines are absolutely where they should go. As for gas getting to the engine, i have no idea.
Old Jul 25, 2017 | 09:39 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
You got some lines crossed. Did you do a trap door?
Old Jul 25, 2017 | 11:33 AM
Engine: 5.0 TPI
Yes but i relined them the same i thought. There was already an access panel cut from the previous owner.
Old Jul 25, 2017 | 11:44 AM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
If you got the return line crossed with the vent line, which would be easy to do, then it could easily do that. Would be a bit more of a feat to mix up the feed and vent line. Did you put in a new sending unit or disconnect the lines down below?
Old Jul 25, 2017 | 11:48 AM
Engine: 5.0 TPI
Disconnected the lines below. Do you have a diagram showing the connections?
Old Jul 25, 2017 | 11:55 AM
someone972's Avatar
Engine: 5.7L TPI
This is the best I could find (thanks Photobucket for taking down all the photos ). I believe they should all keep the same order after the bend, but be careful and double check.
EDIT: That's vent, charcoal canister, return, supply from left to right by the way. It's a bit hard to read if the image isn't full size.
Old Jul 25, 2017 | 02:41 PM
Engine: 5.0 TPI
It seems as if the lines would have to cross to get to those positions on my car.
Old Jul 25, 2017 | 04:51 PM
someone972's Avatar
Engine: 5.7L TPI
The lines will preserve that order if you have a stock sending unit. They go towards the front of the car then take a right angle turn and go down the side of the tank. The line furthest towards the front of the car should be hooked up to the feed line, and the line furthest towards the back should be hooked up to the vent. Is that how your car is?
Old Jul 25, 2017 | 04:56 PM
someone972's Avatar
Engine: 5.7L TPI
For reference here is what my car looks like where it hooks up to the body lines. The picture is taken looking out towards the drivers side of the car.
Old Jul 25, 2017 | 07:32 PM
Engine: 5.0 TPI
I had the one farthest to the left go to my vent valve. Found my problem and will fix when i get home
Old Jul 25, 2017 | 07:34 PM
someone972's Avatar
Engine: 5.7L TPI
Good to hear you found it. Double check the charcoal canister and return aren't swapped as well; don't want to have fuel being shoved into the canister.
Old Jul 25, 2017 | 07:47 PM
Engine: 5.0 TPI
If there is fuel in the canister what would i do
Old Jul 25, 2017 | 07:48 PM
someone972's Avatar
Engine: 5.7L TPI
Do you actually have that problem or just asking hypothetically? I've never had it happen so I may have to defer to someone more knowledgeable on that one.
