Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Should I change this...
Old Jul 30, 2020 | 02:58 PM
my hemi's Avatar
Car: A few things lol
Engine: 350 tpi supercharged and a 383 stro
Transmission: Both 700r4s
Axle/Gears: 3.23s and 3.54s
Being we have a 383 stroker we had a custom 3 inch air intake made but the MAT temps are getting a little to hot I was thinking of going back to the stock air snorkel but wouldn't it be a restriction on the new motor car is speed density no more maf and I would look Into putting in the air boxes from hawks to make it a true ram air of should I just extend this air intake and put the air filter under the battery tray and out of the engine compartment what do you think?
Old Jul 31, 2020 | 02:00 AM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Re: Should I change this...
Where is the air temp sensor mounted with the First setup? Looks like a nice air intake, I don’t think putting the filter below would hurt one bit
Old Jul 31, 2020 | 05:02 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
before cutting holes in the car, build a wall around the air filter to block heat from the radiator/engine compartment from reach the filter.
also, your MAT temps will go up just due to heat soak, so keep that in mind as well.
Old Jul 31, 2020 | 07:28 AM
my hemi's Avatar
The air temp sensor is right by the air filter..
Old Jul 31, 2020 | 07:29 AM
my hemi's Avatar
I was actually thinking of going back to the stock air snorkel honestly dont know what would work better
shuanm
Jan 30, 2009 10:53 AM
pairtoe
Fabrication
Nov 7, 2006 03:17 PM
kylez28
Jun 6, 2005 04:50 PM
Trypt
Jul 7, 2004 03:28 PM
confucius101
Aftermarket Product Review
Apr 9, 2002 10:47 AM
