Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Ls Swap Fabbed double hump trans crossmember
Old Oct 19, 2020 | 06:46 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Anybody know if someone is selling these besides Hooker? I didnt use their mounts so I doubt it'll work...
86 Camaro , long tubes, ls swapped with set back plates & 350 mounts. The factory crossmember lines up with trans mount about an 1/2- 1 inch further back, I got it to work, but will give me poor exhaust clearance
Old Oct 19, 2020 | 09:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Ls Swap Fabbed double hump trans crossmember
I bought a 5" dia x 6" tube, cut it in half and modified the stock piece.Fits better than the hawks part.
Old Oct 20, 2020 | 10:37 AM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Looks good. Looks kinda thin but definitely want to make something similar
Old Oct 20, 2020 | 02:42 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
It's the same thickness as the stock part, maybe 1/8.
Old Oct 20, 2020 | 03:27 PM
Twin_Turbo's Avatar
Here's one I did
Attached Thumbnails Ls Swap Fabbed double hump trans crossmember -screenshot_20201020-222347_photos.jpg   Ls Swap Fabbed double hump trans crossmember -screenshot_20201020-222508_photos.jpg   Ls Swap Fabbed double hump trans crossmember -20201020_222614.jpg
Old Oct 20, 2020 | 08:42 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Here is another alternative. The pass throughs are at the same angle as the frame rails, 22.5 degrees. The brackets are 1/4” and the tubing is 1 1/2” X .120 wall. The arches were 4” X 1/4” tubing. Exhaust is dual 3”.
Old Oct 21, 2020 | 04:50 AM
Twin_Turbo's Avatar
Nice. The only thing is that it puts a lot of strain on the already puny bolts. I drill and tap the stick threads for m12 and if it has tgat much setback I add another set of nut plates further back. Simply drill tge frame for the hole. Then I use a flare ounch to dimple the frame and weld in a nut and grind it flush.
Old Oct 22, 2020 | 07:40 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Originally Posted by Twin_Turbo
Here's one I did
Looks like the passenger side will not have any space to work with. How are you guys clearing this?
Passenger side
Old Oct 23, 2020 | 02:05 AM
Twin_Turbo's Avatar
Modify headers and some creative routing of the pipe coming off it. I use 2.75
Old Oct 23, 2020 | 12:39 PM
soloc4's Avatar
Passenger side
Remove the heat shield. Also, mine is a manual transmission.
Old Oct 23, 2020 | 05:47 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I cut a notch on the frame, but that's for the cat (this is my illegal exh).Also i'm using 2.5 pipes.If you're just gonna run a straight piece you may have clearance issues, i used several small bends to route the tubing and it doesn't rattle/bang/vibrate at all.Even on crap roads or over r/r tracks
My legal exhaust, i also mounted a heat shield, but on the trans bolts.
Old Nov 4, 2020 | 05:42 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Here's one I did
Does this style scrape the ground over speed bumps, train tracks,etc?
Old Nov 4, 2020 | 05:46 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Here's one I did
I noticed most if not all of you are using a manual transmission. I'm using a 4l60e. I'm able only to get a hump on driver side. I will have to do something different on passenger side.
Edit: also it seems like to get the hump on drivers side, I would have to move/remove the hard metal lines . This wont be a problem because I ran my own fuel lines, but seems like it would be a pita
Old Nov 5, 2020 | 01:35 AM
Twin_Turbo's Avatar
No
Old Nov 11, 2020 | 02:19 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
So I finished the crossmember. Not the prettiest, but it works. Much better clearance
Old Nov 11, 2020 | 05:13 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
This is how I did it:
S***ty Spohn X-member that never fit right (I cut the flanges off it) for reference.
Obviously I don't have a torque arm, but that bracket is easy to fabricate.
Old Nov 11, 2020 | 06:13 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Damn, that's really good. I like it a lot.
Old Nov 11, 2020 | 06:34 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Ha ha yours look much better than mines.. great work
Old Nov 14, 2020 | 10:32 AM
Car: '91 Camaro RS
Thanks man, I made a jig out of the old cross-member to preserve the orientation of all the flanges since all 3 of them are at different angles! I could potentially duplicate it, but I'd have to make a different version for torque arms, and various transmissions.
And of course, ALWAYS use CAD (Cardboard aided design).
Old Nov 14, 2020 | 03:07 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
Yea, nicely done, I used the cardboard design for the offset angle cuts myself
Old Nov 15, 2020 | 01:03 PM
Car: '91 Camaro RS
Now that there's so much room I'm considering doing the exhaust in 3.5" instead of 3".
nebz90
Feb 15, 2017 03:06 PM
scooter
Oct 14, 2011 05:41 PM
1987earthquake
Jan 28, 2008 02:56 PM
REALPOWER
May 8, 2005 09:45 AM
Opha
Aug 22, 2003 10:11 PM
