Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Building a 8.8
Old Jan 22, 2021 | 05:12 AM
onebdgti's Avatar
Building a 8.8
I am picking up an 8.8 after work to put in my 87z28. Does anybody know were i can buy the shock mounts, spring perches, and torque arm mount to weld onto the 8.8. Yes i can cut them from the original axle i wanna keep my car mobile till this one is built.
Old Jan 22, 2021 | 06:43 PM
BrianI's Avatar
Re: Building a 8.8
You can buy them new but they are really expensive. I would try to find a housing in a junkyard or from someone parting a car.
Where are you located? I have a housing that I would sell in Lexington, KY
Old Jan 22, 2021 | 06:44 PM
onebdgti's Avatar
Re: Building a 8.8
Im in St. Albans, WV. Its not a bad drive to Lexington from here.
Old Jan 23, 2021 | 06:59 PM
BrianI's Avatar
Re: Building a 8.8
https://www.racecraft.com/housing-br...kit-p-706.html
https://midwestchassis.com/products/...ng-bracket-kit
I have the housing in storage and checked it out today. Its actually a 9 bolt housing and wouldn't be a candidate if you wanted to use the actual tubes. The options above may be better suited.
Old May 9, 2021 | 11:33 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Building a 8.8
When I built my frankenstein 8.8 I was also curious about buying the shock and spring mounts but I found the price to be pretty egregious. You could make your own out of 1/8" plate and tube pretty easily. I did what you mentioned and cut the tubes off of a donor thirdgen rear end housing so my car stayed mobile until it was ready to swap. I have my rear end build somewhat detailed in my build thread.
rufaast
Nov 3, 2017 10:03 AM
Atilla the Fun
Aug 22, 2009 12:40 PM
maroman88
Aug 4, 2005 12:26 PM
