Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Retrofitting 69 floors into a 91?
Old May 9, 2021 | 06:55 PM
Johncassonova's Avatar
Car: 91 z28 prostreet
Engine: Tpi 350
Transmission: Slushbox
Is there a way to fit a whole section of floor in a 91 from a 69 can't seem to find one for a 3rd gen. I know that the torque boxes are going to be a problem but is the driveshaft and torque arm able to fit? Even if the rear is off center for those and is there anything else to be concerned about maybe where the trans bolts in on the frame rails?
Old May 9, 2021 | 07:33 PM
NoEmissions84TA's Avatar
Re: Retrofitting 69 floors into a 91?
Just my opinion, but you already identified a major problem - frame rails.
The 69 had them, the 91 is unibody - no frame rails.
Of course a really good fabricator can make anything work, but why do you want to do that?
http://autobodyspecialt.com/chevrolet/camaro/1982-1992/
Old May 9, 2021 | 07:49 PM
Engine: Tpi 350
hmm.... I thought they where all unibody in first and second gens i found a 69 reproduction floor pan thats got the whole sitting area for real cheap and instead of just sections I just wanted to drop the whole thing in and weld it in instead of trying to play where's waldo with the pieces
Old May 9, 2021 | 09:40 PM
Maybe I am confused. Did the 1st gens have frames?
I know the 2nd gens had front frame rails that would unbolt from the body.
Edit: internet says front half is a "frame". Firewall back is unibody design.
Old May 9, 2021 | 09:44 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
1st gen unbolts like 2nd gen
1st gen rear steering box, 2nd gen front steering box
Old May 9, 2021 | 10:18 PM
Engine: Tpi 350
ah ok its a sub frame I can work with that I'll build a sub frame got it thanks guys
Old May 11, 2021 | 07:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Third gens do not have a subframe like first and second gens. The frame rails are just thick boxed sheet metal that are part of the entire body structure. Third gens have a front crossmember for steering components that bolts to the sheet metal front frame rails. Third gens also use a sort of macpherson strut type front suspension but instead of the spring being on the strut/shock, it's between the lower control arm and the frame rail. First and second gens are upper and lower control arms with a spring between the control arms.
Old May 13, 2021 | 01:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
No this won't work.
Old May 14, 2021 | 10:17 AM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Definitely not the the best approach, that's for sure.
Old May 14, 2021 | 05:45 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Google it looks like Summit has them, CarID has them look around.
Old May 17, 2021 | 10:30 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
The amount of fabrication required would be a lot, by the time your done there probably wouldn't be too much left of the 69 floor pan.
1991 Chevrolet Camaro Parts | Body Panels | Floor Pans | Classic (classicindustries.com)
Goldenbullet44
Apr 15, 2010 01:04 AM
heavy_chevy29
Mar 12, 2006 02:39 PM
fazool
Aug 5, 2002 08:38 AM
91B2L
Jan 20, 2002 08:11 AM
MATEOZ28
Feb 2, 2001 08:56 PM
