FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Engine oil choice....
Old Aug 12, 2011 | 03:30 PM
  #51
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Engine oil choice....
i use royal purple 1030 synthetic. I dont run less than a 1030 unless it is in a newer car that calls for less. the new cars have aluminum blocks with tighter clearances so the thinner oil is needed. and your oil pressure may be fine but is the engine really being lubricated the way it should be.
Old Aug 12, 2011 | 03:48 PM
  #52
OLDYELLR's Avatar
Car: '85 IROC
Don't be misled by the 0W30 viscosity rating. It just means that the oil is like #30 at running temperature and like #0 (whatever that means) at zero degrees for easier cranking and oil flow. It has a shallower viscosity curve than 10W30, which means it's actually thicker than 10W30 when you're overheating.
Old Aug 12, 2011 | 04:38 PM
  #53
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
How else do you keep together a 385ci gen1 SBC @ 6700rpm??? No really big clearances need thick oil, especially @ high, sustained rpm. That ain't no drag car....
Old Aug 18, 2011 | 11:15 PM
  #54
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Broke in my 355 with pennsoil 10w40 dropped down to royal purple 10w30 after roughly 1500-2000.
Old Aug 19, 2011 | 12:42 AM
  #55
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Royal purple 20w50 in mine...plus Lucas oil additive. Anything less and it knocks :/
Old Sep 6, 2011 | 09:09 PM
  #56
SXN's Avatar
SXN
I'm using mobil 10W30 on my 84 TA 5.0L
Old Sep 7, 2011 | 07:30 PM
  #57
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
i use 5w30 royal purple in my car there in my tranny and rearend to and coolant
Old Sep 8, 2011 | 11:09 AM
  #58
SXN's Avatar
SXN
I noticed that you had the 700R4.. u use Royal purple ATF in it?
How does it shift??
Old Sep 8, 2011 | 11:35 AM
  #59
How does it shift??
it shifts fine i also have a corvette servo and it shifts very hard from 1-2-3
Old Sep 8, 2011 | 02:44 PM
  #60
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Do you mean firm, or hard?
Old Sep 9, 2011 | 10:35 PM
  #61
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Old Sep 9, 2011 | 11:19 PM
  #62
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
valvoline 10w40, always run that since i changed the oil day after i got the car, runs good
Old Sep 10, 2011 | 02:17 AM
  #63
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I recently switched to Amsoil Z-Rod 10w30 and I noticed a decrease in "cam chatter" after doing so.
Old Sep 10, 2011 | 09:29 AM
  #64
I have never heard of cam chatter. Do you mean lifter noise?
Old Sep 10, 2011 | 07:51 PM
  #65
Car: 1985 Z28
Yeah that's what I meant lol. Half asleep. That faint and mellow, "plink plink plink plink plink..." you hear when the engine is idling.
Old Sep 12, 2011 | 11:20 AM
  #66
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Rotella T high zinc 10w-30 good for flat tappet cams.
Old Sep 12, 2011 | 02:37 PM
  #67
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Better double check, EPA has made them remove all the good stuff from oil, even diesel oil.
Why the rash of "break in" oils as they are a loop hole to the law, as they assume your only gonna use it once
Dino + ZDDP
Old Sep 12, 2011 | 02:47 PM
  #68
midias's Avatar
Dino + ZDDP
Trust me I have as per my last communication with Shell on June 27th this year they are still at a minimum of 1200ppm ZDDP in rotella T triple protection.
Not as awesome as before but still well above regular motor oil and good for flat tappet cams.
Old Sep 12, 2011 | 07:29 PM
  #69
Rotella has an oil called high zinc?
Old Sep 12, 2011 | 08:19 PM
  #70
midias's Avatar
It is actually Rotella T triple protection it is designed to meet CJ and CI requirements and has 1200ppm zddp at least according to the email i got from shell. I use the 10w-30 but it also comes in 15w-40
Old Oct 3, 2011 | 02:47 PM
  #71
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
switched to Mobil 1 Synthetic today in my ZZ4.
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
