FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Vacuum Diagrams
Old Aug 26, 2011 | 12:26 PM
  #51
keepthefaith's Avatar
Re: Vacuum Diagrams
Originally Posted by KITT1983
hey do you know where i can get an egr solenoid for a 1983 crossfire firebird
Sorry, no. If you are not looking for a perfect restoration part, almost any of the other GM models' factory EGR solenoids from the early 80 will be darn close if not the same. Good boneyard hunting!
KTF
Old Sep 14, 2011 | 05:44 PM
  #52
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Re: Vacuum Diagrams
Hey if any body could help my I need a vacuum diagram for a '87 LS Camaro 2.8L Crossfire Multi-port fuelinjected v6. TBI and TPI diagrams do not work for my style motor. Thanks for any help.
Old Oct 15, 2011 | 03:42 PM
  #53
iggyone's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0L
Re: Vacuum Diagrams
What will i need to replace my egr valve? I have a camaro rs tbi 305 5.0ltr. My car flutters when i dont give gas. Acts like it wants to turn off but doesn't. I had a diagnostic done a year ago and they said I had a Minor leak at the egr. So i assume thats the problem
Old Oct 16, 2011 | 06:02 PM
  #54
Re: Vacuum Diagrams
Hi, I would make double-sure that it isn't something else first. Do a tune-up, check for vacuum leaks (those rubber lines aren't getting any younger), and try some injector cleaner in the tank. If the EGR does need replacing, they are pretty reasonable at the auto part stores. I like to check online first so I have the correct part No. and price before I walk in the store. Also, be very careful as to which line goes where as I noted in an earlier post (the solenoid valve is specially designed to be connected one way only).
Good luck!
Old Nov 4, 2011 | 04:36 PM
  #55
Eclipsegs621's Avatar
Car: 84 Camaro
Re: Vacuum Diagrams
Does anyone have an actual pic of the car for a 84 Berlinetta for the TVS swirtch? I need to replace or bypass mine. It broke off and i have no idea where to connect a new one. My water neck has a TVS switch on the right side of the neck and a coolant temp sensor on the left. I have the SB 305 W/4BBL
Old Jan 23, 2012 | 12:57 PM
  #56
moronmechanic's Avatar
Re: Vacuum Diagrams
go with the 86-89 since they uused the Mass Air Flow the 90-92 switched to the speed density.
Originally Posted by coyote452002
Guys I just bought a 91 Camaro Z28 Convertible, it had a 305 TBI. I did away with it and I installed a TPI system from a 1989 IROZ with a Mass Air Flow Sensor . I kept the original 1991 vent canister wich has a different diagam. My question is, should I set the vacuum lines up as the TPI 90-92 or should i find the vent canister for a 86-89 TPI?????
Old Apr 9, 2013 | 03:40 PM
  #57
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Vacuum Diagrams
A post with many diagrams in it:
https://www.thirdgen.org/forums/tech...iagrams-i.html
Old Apr 15, 2013 | 09:16 PM
  #58
scootter2012's Avatar
Car: 84 trans am
Re: Vacuum Diagrams
Originally Posted by Benm109
I'm assuming it's the 86 in your sig:
Also, for anyone who is looking for vacuum diagrams for your 3rd gen, just go to link below. It's got all the vacuum diagrams for the different engines over the years. Here it is: http://www.autozone.com/servlet/UiBr...3d80163807.jsp
the links are dead
Old Oct 1, 2013 | 12:16 PM
  #59
slowboy's Avatar
Car: 1990 CAMARO RS
Engine: 350 - replaced 305 with 350
Transmission: 5 SPEED
Axle/Gears: STOCK [?]
Re: Vacuum Diagrams
need hoses diagram from air pump to diverter to manifolds to catalytic converter please
Old Oct 2, 2013 | 04:52 PM
  #60
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Vacuum Diagrams
Sorry man. Those aren't vacuum lines. But I'll still hook you up. I need to know the year and model of your Camaro. What I will do is take a screen print of my parts and illustration of the emissions system. It should show everything you need. I'm currently at school right now. Bit I'll try to remember when I get home.
Old Oct 2, 2013 | 11:00 PM
  #61
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Vacuum Diagrams
www.camarosource.ca has diagrams in their tech sections
Old Oct 3, 2013 | 06:41 AM
  #62
slowboy's Avatar
Car: 1990 CAMARO RS
Re: Vacuum Diagrams
yea I know they aren't vacuum lines, but I couldn't find anything on here about the emissions hoses...my Camaro is a 1990 RS, 305 has been replaced with 350, and 5 speed...
Thanks for your help!!
Keith
Old Oct 30, 2013 | 08:40 AM
  #63
HighPressure's Avatar
Car: Pontiac Firebird ´87
Engine: L69 305
Re: Vacuum Diagrams
the diagram doesnt help a lot when everything is disconnected..
can anyone point out, what needs to be connected where?
L69 H.O. CCC Quadrajet
Old Feb 28, 2017 | 02:01 AM
  #64
Dinero's Avatar
Car: 1988 GTA
Engine: 5.7
Re: TPI Vacuum Diagrams
Here are 2 different vacuum diagrams for the TPI system. Just follow the link. https://www.thirdgen.org/forums/post...48-post12.html
Not sure if it is ok to ask a question if thread is this old. Thanks for the diagrams. Just to make sure on the 87-89 tpi engine, the top tip of the two vacuum tips on the canister, the top tip hose would route to the plenum? It seems that way from what I can see.
If that is the case I have the 2 lines transposed. the top tip hose(control valve) hose going to the plenum the bottom tip hose going to the fuel return line. What would this cause? Thank you Chevy86
Old Jul 26, 2017 | 07:31 PM
  #65
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: Vacuum Diagrams
pretty much all the diagrams can be located within this post
https://www.thirdgen.org/forums/tech...al-sticky.html
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
