FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Alignment Setting, Optimal
Old Feb 6, 2005 | 12:55 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Is this a good setting for strait-line street racing?
Caster +4
Camber 0
Toe 0
Is there any advantages/disadvantages to this setting? IS there a better setting to use? (street driving only)
Old Feb 8, 2005 | 01:08 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
-.5 Camber
Old Mar 5, 2005 | 12:59 AM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Every try pushing a shopping cart fowards when the wheel is facing the wrong direction and its all wobbly as hell? Well thats what +4 caster is, negative caster will always make the car more stable.
Old Apr 8, 2005 | 11:05 PM
Car: 1988 SC Camaro
Engine: 305 TBI
positive caster
actually, i think more positive caster keeps the car stable at higher speeds....i just don't know how much positive caster to go with...
Old Apr 8, 2005 | 11:48 PM
Transmission: th350
Re: positive caster
Sorry bro your wrong, think about the whole shopping cart analogy. Its the easiest way to explain it. Positive caster yields easier steering ability yet less stability. Negative caster is the opposite.
Old Apr 9, 2005 | 06:23 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Both of my Camaro Performance books say that more positive caster gives you more stability but harder to steer the wheel...I'm just going by what these two written sources claim...One of these books is "Camaro Performance Handbook" by David Shelby, and the other is "how to tune and mofiy your Camaro" by Jason Scott....in fact, there is a chart that gives the optimal caster setting for racing...all of them are Positve, around 4,5, and 6....so i'm just going by this...
Old Apr 10, 2005 | 09:17 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
from the FAQ section of this board
Q: What are some suggested front end alignment specs?
A: A table in the Camaro & Firebird Perforamnce Handbook for 3rd Generation cars lists the following recommendations:
Code:
                      Caster           Camber          Toe Total
                       (deg)            (deg)            (in)
                     L      R         L        R
   Street           +4    +4.5       -.5      -.5        3/32
   Hard Street Use  +5    +5.5       -1       -1         3/32
   Drag Racing      +4    +4          0        0         1/32
   Road racing      +6    +6         -1.75    -1.75      Short Course
                                                          1/8 out
                                                         Long Course
                                                          1/16 in
The figures are credited to Global West Suspension Components and are taken with driver weight included
Old Apr 10, 2005 | 09:42 AM
Transmission: th350
Hmmm very interesting, guess ive been doing it wrong for a few years than. *shrugs* Its just what i was taught when i went to UTI. Hmmmm *shrugs* oh well, my bad.
Old May 23, 2005 | 07:10 PM
savoo's Avatar
Car: 89 camaro rs T-top
Engine: V8
Transmission: auto
Bigwelch, look at your pic.
the farther back your tire footprint is from your turning axis the more stability you will have. As with the shopping cart the wheel wants to follow the axis. Also with the caster (+) when you turn the wheel it will raise the car. So gravity also helps straighten the wheel. savoo
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
skip91
Sep 24, 2015 03:29 PM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
