WC T5 Speedometer Gear Installation
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Changing the speedometer gears in your WC T5 can be done with the transmission in or out of the car. The following write up was done with the transmission out of the car.
New speedometer gears
However if you do this swap with the transmission in the car here are a few quick reminders and starting tips.
In the car
If you choose to leave the transmission in the car you will have to remove the torque arm mount, driveshaft and transmission cross member. You will also have to remove the center console so that you can unbolt the shifter. Once these items are free the transmission will sag and hang only with the support of the motor mounts. I would leave a jack under the transmission at all times.
Step one: Remove shifter (The shifter will already be removed if the transmission is already out of the car)
The first thing you will have to do is remove the shifter. It is held down with four bolts. Remove the bolts and slightly pry on the shifter to break loose the seal.
Shifter removal (in pic console, and rubber boot have been removed)
Step Two:
The next step you will have to free the offset shift lever block from the input shaft. Locate the small hole on top of the block directly underneath where the shifter would be. You will need a roll pin punch at this time. Take the punch and place it on the hole. Give it a few smacks with a soft hammer until the pin is fully depressed into the offset shift level block.
Roll Pin Punch
Step Three: Extension housing removal
Locate the bolts that hold the extension housing to the rest of the transmission. Remove these bolts and slide off the extension housing. Have a catch pan ready because you will loose all your fluid (4 quarts or so).
NOTE: As you remove the extension housing pay attention to the offset shift lever block. Right before the extension housing is free you can grab and remove (slide rearward) the offset shifter block. Go slow and be sure to grab the roll pin, spring, and ball. They can be easily lost so go slow and catch them.
Offset shifter lever block components
Now that the extension housing is out of the way you can see the speedometer gears. The driven gear is in the housing located on the VSS unit and the drive gear is the round gear that surrounds the transmission input shaft.
In the car
Step Two:
Roll Pin Punch
Car: '90 RS
Engine: 377 LSX
Step Four: Drive gear removal
Before you remove the drive gear you will have to remove a c-clip. I use a 30mm open ended wrench and place it on the front face of the clip. I then strike the wrench with a soft mallet and slowly work the clip off of the input shaft. You will then have to slide the rubber seal off. You can now remove the gear. Take note of the clip that holds it to the input shaft. This clip will need to be depressed as you remove the gear. Removal of the gear is the same as the c-clip. Use a 30mm (1-1/4” or crescent wrench should work too) open ended wrench to tap the gear off. If you do not depress the clip you will break it. If you do (and I did) you can get a new one from your GM dealer for under $3.
Place wrench on gear and then tap on wrench to remove gear and c-clip.
Step Five: Drive gear installation
You can now install the new drive gear in the same manor that you removed the old one. Tap it on softly with a wrench and mallet. Be sure that you have the clip hole aligned with the gear slot. If you do not the retaining clip will not seat and you will have to slide the gear off and start over. After you have the new gear in place slide the seal back in place. You can now tap on the c-clip. My c-clip install tool was not adequate given the size of this clip so I used a 1-1/4” socket as a guide. I positioned the c-clip on the end of the tail shaft and tapped it on with a socket. I then used the 30mm wrench to guide it into its final position.
Allignment of gear slot with input shaft hole
Step Six: Driven gear removal and installation
Remove the VSS from the extension housing. It is located on the side and is held in with one ten mm bolt. When you pull it out you will see the gear on the end of the shaft. Pull the gear off of the shaft. If you push down on one end and pull at the same time it will slide right off. Pulling directly on it will not allow it to come off easy. Some people immediately put the new gear on but I wait until I have the area prepped for reinstallation. Take some brake cleaner and clean off the old RTV and oil from the VSS bung. Remove any large chunks of RTV that are lodged into the o-ring on the VSS. Drop the gear into the bung and place a small bead of fresh RTV around the opening. I drop the gear in first in order to prevent RTV from getting on the gear. You can now slide in the VSS and nest it with the new gear. When it sits into place reinstall the ten mm bolt.
VSS with gear removed
Drop gear in before RTV
RTV on VSS bung
If you look down the extension housing you can see the new driven gear.
Step Seven: Extension house reinstallation
At this time you can now install the extension house. As you feed the housing onto the input shaft you will want to slide on the offset shift lever block making sure to properly seat the spring and ball. When the offset block is in place, tap in the roll pin so that it is flush with the top of the block. You can now place a bead of RTV around the mating surface of the extension housing and the rest of the transmission (prepare the surface in the same manor you did for the driven gear). Slide the extension housing into place and reinstall all bolts.
You are now done and can reinstall your transmission in the reverse of removal.
This is a quick overview and I will be adding/editing this over the next few weeks when I can get back to my shop. More pictures to come. I hope this helps those who ponder this swap. It isn't that hard. Just messy.
RTV on VSS bung
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Freaking awesome! Thanks for the post, your timing couldn't be better!!
BTW - What rear gears were you changing to?
Car: '90 RS
Engine: 377 LSX
I went from 3.08's to 3.42's.
Car: 1991 Chevy Camaro
Engine: 305 TBI
Great post.
I little tip I learned back when I replaced my speedometer gears was to heat up the drive gear to make it slide on easier. Just stick it in a bowl of water, heat it up for 1 or 2 minutes, and it should slide right on the output shaft without any tools. That also makes it a whole lot easier to align and get the clip in.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I'm doing the same thing in a few months and have already done it on a couple 700r4's. But I always worry about the offset block, spring, and ball not coming off right or not going on. Do you have more pictures of that or am I making an easy task harder than it needs to be?
Car: '90 RS
Engine: 377 LSX
Car: 89 IROC-Z
Engine: 383 stroker
Transmission: WC T-5
Axle/Gears: 2.77
shifty, where can i buy a mechanical speedo for a 91 WC T5 ? it has the electroic setup now, but my guages are for the mechanical?
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Hey Shifty, If you dont mind whats the part number of the vss in the picture? If you know /remeber
the ones ive been trying to order are all discountinued and my next step is to resort to getting a dash mounted vss and wiring it into the oem wiring.
Car: '90 RS
Engine: 377 LSX
That is my stock VSS so I do not have the p/n off hand. Any GM parts dealer should be able to look it up for you.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 95 z28 camaro or 92 k5 Blazer
Engine: LT-1 fo the Z. vortec fo K-5
Transmission: 4L60E=Z junkR4=K-5
Axle/Gears: 3.43=Z / 3.73=Blazer
Re: WC T5 Speedometer Gear Installation
i need help. my car broke its speedometor back in the winter.
1 dose the 0-145 work correctly if i install it even if mine is the 0-110
2 is there a cheaper way to fix it without another speedometer somewhere else
3 dose anyone know of any new or used speedometers for sale cheep.
Car info 1991 z28 camaro 350 700r4. i replaced the 700r4 with one from a differant camaro that the speedometer was cable driven so i replaced the cable drive with the sensor from my old tranny it worked for a while and broke.
Any suggestions are helpful. until i fix it mom will make me drive my 91 bonneville. such a boring transition.
PLEASE HELP
PLEASE HELP
I just want to add some critical info here guys. You MUST make sure the shifter is in neutral in the 3-4 position when you drive out the Offset Shift Lever. If you fail to do so, you'll be pounding the roll pin into the Detent Guide Plate!!
Good luck.
Steve
Good luck.
Steve
Car: 1988 Iroc convertible
Engine: 305TPI
Transmission: T-5, swapped it in.
Axle/Gears: no clue, but I'll learn
ok, so I had a tranny swap done on my 88 IROC. The T-5 is an 83 NWC. Is this the same as you're describing, and any suggestions on finding the speedo gear? Have searched far & wide...thanks!
Car: 85 Iroc-Z
Engine: lb9
Transmission: W/C T5
Ok I need Help. Did this the other day, and now i cannot get the tail shaft housing back on. It fit when i test fitted it, but had a problem with the offset shift shaft spring and ball, so had to take it back off and now the houling will go on until it is about 3/4 of an inch away from complete and it wont go any further like it is hung up on something. Everything looks ok any ideas help please!!!!!
Car: 91 Camaro RS
Car: 85 Iroc-Z
Engine: lb9
It already is out i have it to do a auto to man swap, and was doing this before i install it.
Car: '90 RS
Engine: 377 LSX
Car: 85 Iroc-Z
Engine: lb9
I have tried it now, but afraid to tap to hard, plus it feels as though something isn't lined up. I do remember when i took it apart a week ago the shorter shaft that has the fork off of it had some play, and now it won't move could it have gotten messed up, I know that in pulling the case on and off a few times the shift shaft has been cought and shifted into a geer. moved it back to neutral i thought? Did I mess some thing up? this prodject is beging to get bigger than me.
Car: '90 RS
Engine: 377 LSX
Car: 85 Iroc-Z
Engine: lb9
ALLRIGHT That Worked!!!!!!!
Thanks man Fhewwww. not so scared that i messed it up now
Thanks man Fhewwww. not so scared that i messed it up now Junior Member
Car: 1991 CAMARO RS
Engine: 3.1 V6
Transmission: 5 SPEED
i know this is a old post but the information is great. i have a question/need help. the gears are discontinued from gm. i am now left with looking in a salvage yard. my 1991 camaro has the vss with the plastic gear. gm did not offer a 20 tooth vss gear. they did make a 20 tooth gear with the steel shaft. what was the application? the only info i can find is the part number superceeded to a new number in 1984. the small gears with the steel shaft....pickup truck?...vans?... camaros?.. only 2wd manual trans vehicles?. i would guess with a 3.73 it would be a truck. i went last saturday and pulled several speedo housing looking for steel shaft gears with no luck. i found several solid plastic gear/shaft gears.
what does the steel shaft small gear fit?
thanks,
don
thanks,
don
Car: 1991 CAMARO RS
Engine: 3.1 V6
YEA!!! I FOUND ONE. it came from a internet site called speedometer solutions. it was his last 20 tooth though. he did say he had one 19 and two 22 tooth gears left. also i was supprised to find that the gear was not blue.....yes not blue. it was definately a 20 tooth. it has a tiny 20t on one side of the gear.
the 20 tooth gear is a hard item to find. a used one will have to come out of a 1987-1988 firebird with a 5 speed and a 9 bolt borg warner rear axle with a 3.46 gear. the steel shaft 20 tooth gear will also come from full size trucks around 1984 with a 5 speed. the problem with the gears with the steel shaft is gm stopped making them. the gears would come off the shaft (i'm told by gm). many were replaced by the plastic shaft type. so even if you are lucky enough to find a truck with the 20 tooth gear its a good chance it will be the solid plastic type.
thank you to those who tried to help.
thanks,
don
thanks,
don
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
