FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Difference between trans am and formula
Old Oct 25, 2006 | 06:27 PM
mach158's Avatar
How can i tell the difference between a formula and trans am? The VIN just narrows it down a either one how else can i narrow it down?
I tried and search and didnt yield any results but if i missed something let me know.
Edit: car is an 88 and this is part of the VIN 1G2FW21E7JL
Old Oct 25, 2006 | 09:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i believe all formula cars had ws6 suspension so you could check for that. also trans am cars had a body kit formula cars did not. if you run the vin # it should tell you specifically if it is a formula or a trans am.
Old Oct 25, 2006 | 09:35 PM
mach158's Avatar
i find a VIN decoder on google and for the letter it says formula/trans am
I assume if i look at the RPO codes i may be able to tear it apart and help determine what it may be?
Old Oct 25, 2006 | 09:38 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
if the tail lights look more like blackouts, then its a trans am. Also the formula's had a slight (and i mean slight) cowl hood.
Old Oct 26, 2006 | 10:34 AM
latrobefbody's Avatar
Car: 83 Trans Am / 79 Camaro/dune buggy
Engine: 400 TPI/406 /1911
Transmission: WC T-5/ T-56 (looking)/bus trans
Axle/Gears: 3.42/3.73/4.56
WS4 is Trans Am conversion
WS6 is Formula suspension but there are T/A's with WS6 suspension.
Old Oct 26, 2006 | 12:36 PM
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
Formulas were more bare bones performance-oriented, no body flares and a minimum of power options inside. That's why I like 'em!
Old Oct 26, 2006 | 03:30 PM
mach158's Avatar
well here is a side shot and the only shot i have of the tail lights maybe that can dicifer something? I'm going to check out car saturday and if i knew it would help in negotiations.
Old Oct 26, 2006 | 07:37 PM
Car: 92 Camaro
Axle/Gears: S60 373
looks like a TA to me.....
Old Oct 26, 2006 | 07:52 PM
Ironmahn's Avatar
Car: 1986 Trans Am
Is that possibly a clone T/A, where is the air vent in the rear of the fender by the door? I would check RPO's and VIN, I don't know if all the RPO's have the VIN on them but mine does. Although that could be changed out from a donor car. I would do some more homework before purchasing if you are paying a large sum of $$$$ for it, .
Old Oct 26, 2006 | 07:54 PM
mach158's Avatar
well going to buy it for $1,200, sound fair?
Will check the RPO's tho, i'm betting its only a formula but its either one so i figure for the price i cant really complain.
Old Oct 26, 2006 | 09:12 PM
Car: 92 Camaro
Axle/Gears: S60 373
well what is the milage on car? engine? tranny? any mods?
The body looks like formula but tail lights like trans am.....could have bought TA rear lights....not sure ab this one..
Old Oct 26, 2006 | 09:14 PM
mach158's Avatar
engine is not original, supposed to have 350 in it now, has a 5 speed, no mods i know of besides adding hood, and mileage unknown
Old Oct 26, 2006 | 09:50 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
Formulas all came with a power bulge(offset) hood, 16 inch wheels and a wrap around style rear spoiler. You didn't mention what year that car is but it looks like it might be a firebird thats a TA clone.
Old Oct 26, 2006 | 10:03 PM
mach158's Avatar
whoops sorry thought i had that in the first post, its a 88, VIN makes it as either a formula or trans am.
Edited fist post with year and partial VIN
Old Oct 26, 2006 | 11:17 PM
Car: 91 Formula WS6
Formulas do not come with the body molding trim pictured.
Old Oct 26, 2006 | 11:20 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
What does the seller says it is. If he says it a TA and it turns out to be a TA clone, then the 350 is likely a 305.
Seems kinda shaddy to me
Old Oct 27, 2006 | 02:18 AM
Firebat's Avatar
Just by looking at it(no vin/rpo checking). Any chance of it being a Trans Am GTA with the GTA emblems removed? I dont see fender vents and if there aren't any, then the front fender isn't from a trans am. The spoiler isn't original for that hatch, notice the clips on the glass left from a wrap-around spoiler.
The dash pocket should say trans am or gta also if its a trans am or trans am gta.
edit:according to the engine code shown in the vin, its not a gta
Old Oct 27, 2006 | 04:45 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
At that price, a test drive's going to be the only real way to tell if you want it. It looks to have been repainted, those rims aren't stock of course, and the hood's been swapped. The car looks good, just needs a decent set of wheels and it'de be a head turner. At 1200 if it runs and drives nice I wouldn't pass it up for a driver car. It doesn't have alot of value as a collectors item seeing as how alot of parts have been swapped etc.
Old Oct 28, 2006 | 06:32 PM
mach158's Avatar
the car is a trans am, engine is infact a 350, decoded the casting on mortec, drives good and hauls, only problemn is being cold blooded tbi
Old Oct 29, 2006 | 11:35 AM
Car: 92 Camaro
Axle/Gears: S60 373
tbi huh? yeck! I say get mini ram or HSR or some other type of aftermarket manifold and get that thing. he wants 1200? id tell him a grand take it or leave it
Old Nov 7, 2006 | 12:28 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Thats gotta be a Formula! The original engine code is E. As far as I know of... A Trans Am never came with TBI. TA's only came with 305 or 350 TPI motors. Which are vin codes 8 or F.
Old Nov 7, 2006 | 01:25 PM
Firebat's Avatar
Some Trans Am's had TBI. Now, the Trans Am GTA came only with TPI, except the 89 TTA.
Old Nov 17, 2006 | 07:24 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its a base firebird. Look at the spoiler. Trans Am's and Formulas had wrap arounds.
Old Dec 19, 2006 | 03:56 PM
birdsgonnafly's Avatar
Car: 87 T/A
Engine: none right now
Transmission: prob th350
My trans am came with the vin H and the gfx dont match the color they seem to be just stuck on there
Old Dec 20, 2006 | 02:21 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
look for vin#s on the bumpers/hatch. no formulas came with that rear spoiler.
POZ
Old Nov 25, 2008 | 08:04 PM
allenfre's Avatar
Re: Difference between trans am and formula
and please take note that T/A weighs more. Though they got the same HP, so I'd probably get a formula than a Trans.
Jorlain
Aug 24, 2022 05:11 PM
theshackle
Sep 17, 2020 08:26 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Jlanz55
Aug 17, 2015 07:15 AM
