FAQ Building Board This isn't a "question" board. This board is where we all can figure out what we need added/changed to the FAQ on thirdgen.org.
Will a Mustang T5 or Tremec fit my car?
Old May 18, 2000 | 01:20 PM
Chuck Everly's Avatar
No. The bolt pattern, input shaft, output shaft, overall length are all different and the F-body T5 is rotated 18*.
The Tremec can be bought to fit the F-body. The only place I know to get the conversion kit is Fortes Parts Connection. This kit includes a Tremec 3550 or TKO, new input shaft, heavy-duty driveshaft yoke, adapter plate that matches the T5 bellhousing to the Tremec (this also makes the Tremec long enough), speedometer adapter, shifter and crossmember adapters. You will use the stock F-body clutch.
Old May 18, 2000 | 03:05 PM
Get Blown ?'s Avatar
Next Generation sells them too.
$1699 for 3550
$1999 for TKO
PurelyPMD
May 5, 2016 04:57 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
okfoz
Sep 22, 2015 03:37 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
