FAQ Building Board This isn't a "question" board. This board is where we all can figure out what we need added/changed to the FAQ on thirdgen.org.
Axle Splines
Old May 18, 2000 | 12:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Axle Splines
Q: What axles are in my car?
A: 82-88 thirdgens have 26 spine axles. 89-92 cars have 28 spline axles, same as the 4th gen. 89 was a transition year. Some cars have 26, some cars have 28. The only way to know for sure is to open it up and check.
1991 Camaro Z28
5.7L 5-Speed
13.32 @ 105.27 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Webmaster: ICON Motorsports
Old May 18, 2000 | 01:06 PM
Chuck Everly's Avatar
It is true that the axles splines are the same on the 89-92 3rd gens as the 4th gens. But the 3rd and 4th gen axles are not interchangeable. The 4th gen axle is about 2" longer.
Old May 18, 2000 | 07:34 PM
84ZZ4's Avatar
Yes, the thirdgen axles are narrower (like chuck said), but the spline count and axle shaft diameter are the same--which means you can use fourth gen ring gear carriers, if you have the third-gen 28 spline axles.
28 spline axles can also be purchased from Moser Engineering (http://www.moserengineering.com/)
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
