86 Trans Am t-top roller $700 Northern KY
Car: 91' RS Convertible
Engine: 305 TBI
I have an 86 Trans Am t-top roller. Its red with silver ground effects (will need paint) car is solid with no rot in which i did a carfax and it was originally from the west coast thats why its not rotted.It has the ws6 package, 4wheel disk brakes, 3.23 posi 9-bolt rearend, new GM ta hood with used vents in primer still. No motor /trans(just pulled for old truck project), Interior not complete it'll be missing seats and console. Car was drivable till about a week ago then i pulled the drive train. I'll take $700 for it. I do have a clean title on it also. I don't have any pics right now. If interested shoot me some questions. May trade?
Re: 86 Trans Am t-top roller $700 Northern KY
As the previous owner of this car let me clarify a few details...
I installed 4th Gen seats, shifter and console in the car. The transmission tunnel has been modified to accept a 4th Gen shifter and console. The way it is right now you cannot put a 3rd Gen shifter back into the car the way that it sits. Also, the plug for the power driver's seat has been cut and now has a plug for a 4th Gen power seat (which worked great when I owned the car). The rear is a 9-bolt posi with 3.27 gears (the car had a 2.77 originally). The driver's side wheel cylinder leaked when I drove it last. It has sat for over a year so I am not sure if it was fixed or not.
The rear area above the gas tank has been cut so that you can get to the fuel pump without dropping the rearend. It also had a brand new Holley FP installed. The car was originally a TPI car. I put an LT1 into the car and the fuel lines have been modified for an LT1 along with the wiring harness. It should have braided fuel lines as well.
The rear suspension should still have BMR LCA's and a Hotchkiss panhard bar along with a custom STB out front. It has good hatch struts too.
The car is a very solid car and was originally from California and Alaska for most of its' life. I went through and fixed the leaks from thr T-tops so it should be nice and dry. Finally, I installed a '91-'92 Z28 spoiler out back so the car does not have a TA spoiler.
It's a heck of a deal for $700 especially if you are looking at an LT1 conversion.
Later,
Lee
Later,
Lee
Engine: 305 TBI
Most likely the car is being traded off tomorrow. I'm still pulling some stuff and swapping. I pulled the lca's and panhard bar in which stockers are there. I never had a strut tower brace for it, that was given to chuck. The was done right but i'm wanting to finish of the Vert and start on one of my of projects. Thanks for the info Lee.
Car: rebuilding a 1987 Firebird
Engine: 350 nuttin to special
Transmission: looking for a 6 speed
Do you still have the car? Where you located?
Engine: 305 TBI
Sorry its gone. I forgot to post an update.
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
Mickeyruder
09-02-2015 02:45 PM
1992 Trans Am
08-08-2015 08:16 PM
3rdgenparts
08-06-2015 09:03 AM
