[MI] 1990 Firebird - 3.1L V6 700-R4 Automatic Trans
Car: 1990 Pontaic Firebird
Engine: 3.1L V6
Transmission: 700-R4
Selling my 90 Firebird - 3.1L V6 700-R4 Automatic Trans
Selling my 1990 Pontiac Firebird, 3.1L V6 700-R4 Automatic Trans.
The good,
Rebuilt and beefed up 700-R4 trans
New Air Con Pump and lines
VATS override system installed with quick disconnects to re-activate the system
Newer Firestone Firehawk Wide Oval Tires (all wheels)
Newer Catalytic Converter and Muffler welds
Replaced T-Top Seals (Cars and Concepts T-Tops)
New Guides for the rear hatch pull down motor.
Replaced Calipers, Rotors, Pads, Ball Joints, Struts (Monroe Sense-Track), Steering Gear, Rear Shocks (Gabrielle Max Controls), Idler Arm, Center Link, distributer, rear axle seals, thermostat, spark plugs, Accel wires installed, radiator and more.
New Black Carpet inside
Interior is nice minus the drivers seat (covered)
New Headlights and re-built pop-up motors
Long service and parts history
JVC stereo and Alpine Rear Speakers
The Bad
No Heat - Valve that diverts hot coolant to the heater core is broken. I have removed it and put in a brass T to allow coolant to flow thru the lines.
T-Tops Leak in Heavy Rain - Not sure what is causing it.
Rust - It is a Mid-West car so there is rust
Needs high beam low beam switch -
Body work - Is not perfect
$2000 or best reasonable offer
Located in Lansing, MI (In a non-heated garage)
http://lansing.craigslist.org/cto/4147862645.html
The good,
The Bad
