Thinking about selling my car. 88 firebird with carbed LS2. I do not need to sell but testing the waters. This car has a lot done to it. It has been to the track a couple times. Runs 10.90-11.2 consistently. Here is a quick list of whats been done. If you have any questions let me know. LS2 swap, cam (have cam card), port and polished 243s with ARP studs, port and polished vic jr intake, 750 quickfuel carb, magnafuel 500 pump, magnafuel fuel log, 2 Holley adjustable regulators, ATI harmonic balancer, ARP crank bolt, TCI flexplate, nitrous express main line kit, Bought it used and installed on car but engine has never seen nitrous ran through it. Build th400 to handle 1k horse, hipster trans brake reverse manual, strange driveshaft, trick chassis crossmember with lop, trick chassis ford 9in, strange 35 spline axles, 389 gears, stock 98-02 fbody rear brakes, 275/55/15 MT drag radials, MT front runners, trick chassis rear double adjustable control arms, trick chassis adjustable panhard bar, founders drop upper panhard bar, spohn subframe connectors, spohn k member. spohn front control arms, UMI strut plates, viking crusader double adjustable coil overs all 4 corners, wilwood front drag brakes, flaming river manual steering rack, strange manual master cylinder, 8 point chromoly roll cage built by trick chassis, corbeau racing seats, corbeau 5 point driver harness, B&M pro stick pistol grip with button.
I have a lot of pictures and videos of it running. Its best to text or call me. 815-529-8212.
I can sell running and driving or as a roller just removing the engine and trans.
running and driving id like to get $11,750
roller id like to get $7500
Located in McHenry IL
Thanks.
Reason: add price
Please make sure to read the Announcements and Stickies as they contain important and frequently asked information. They also cover basic guidelines for using the site and posting ads.
