87-90 GTA WANTED, 305 MANUAL, T-TOPS, DIGITAL DASH, (black preferred)
Subscribe
Jan 28, 2021 | 09:18 PM
Hi all, I am located in Canada but willing to buy from the US. 87-90 GTA, 305 manual transmission, t-tops, and digital dash. Black exterior and camel interior preferred, but willing to swap out the interior as well as paint the car if I can't line up all these variables in one car. Please let me know, thanks!!
Reply 0
Aug 14, 2024 | 01:58 PM
Re: 87-90 GTA WANTED, 305 MANUAL, T-TOPS, DIGITAL DASH, (black preferred)
Add me to this list too
Reply 0
Aug 16, 2024 | 10:17 AM
What is your price range?
I have a straight body, black T Top 1991 WS6 TA with a Blueprint Engines "Cruiser" 350 and a 5-speed TKX with impeccable gray cloth seats. The car Pontiac should've built!
Blueprint Crate Engines Small Block Chevy 350 ci / 341 HP / 371 ft-lbs. TQ - JEGS
WS6, G92 (3.42 gears), N10 (dual cats). No digital dash.
No miles on transmission.
The engine has under 1,000 miles.
SLP runners, retained the TPI.
Tires and brakes have under 1,000 miles.
Stainless brake lines.
I've gone through a lot of the car, replacing fusible links, bare wiring, burnt-out bulbs, and properly remedied any other issues I encountered during the installs.
The AC works but needs a charge.
I also have the original seats (good shape), cats, T5, and 305 that came with the car.
Reply 1
Aug 18, 2024 | 05:40 PM
Wow, nice ride!! I'm looking for a 87-90 more original, but appreciate the post. Thx.
Reply 0
Aug 19, 2024 | 07:33 AM
Quote: Wow, nice ride!! I'm looking for a 87-90 more original, but appreciate the post. Thx.
No problem! For inspiration, heres some photos of an '88 I owned.
Reply 0
Aug 19, 2024 | 07:53 AM
Just as some extra Info to help your search, the Digital Dash was a two year only option on the GTA's for only the 87 and 88 model year. In 1989 they did away with them entirely due to how complicated the engineers at Pontiac made them to work on and install, plus people apparently brought them in for service a lot and were a pain in the *** for servicing at dealers. So your search for Digi Dash will be a bit harder, but you should be able to trace down some LB9 + CC1 combo's. Happy hunting!
Reply 0
Sep 15, 2024 | 04:50 PM
Does it have to be a running car? I have a 87 GTA t top car black interior painted nardo gray, no motor and trans, k member is setup for a ls
Also in Ontario
Reply 0
Sep 16, 2024 | 12:15 PM
Yes, would prefer running (and no digital dash). Thanks thou
Reply 0
Mar 8, 2025 | 09:13 PM
I just relisted my 1990 Black on Black GTA 5speed 1 of 42
1990 GTA T Tops 305 5speed, 92600 miles, 98% original, The body is in excellent condition but the paint needs work, NO RUST!
PM if you would like to talk.
Reply 0
Mar 27, 2025 | 09:39 AM
Quote: Just as some extra Info to help your search, the Digital Dash was a two year only option on the GTA's for only the 87 and 88 model year. In 1989 they did away with them entirely due to how complicated the engineers at Pontiac made them to work on and install, plus people apparently brought them in for service a lot and were a pain in the *** for servicing at dealers. So your search for Digi Dash will be a bit harder, but you should be able to trace down some LB9 + CC1 combo's. Happy hunting!
I think the digital dash had a high failure rate when they were new, often had to be replaced, and that led to them being discontinued. But if you got a good one, they do seem to last. I have one and it's never given me any trouble.
Reply 0
Mar 27, 2025 | 09:48 AM
Quote: I think the digital dash had a high failure rate when they were new, often had to be replaced, and that led to them being discontinued. But if you got a good one, they do seem to last. I have one and it's never given me any trouble.
In my opinion, they're the absolute coolest feature I've ever seen on a car. I prefer them over anything new and modern that's out today. Been searching for a DigiDash car with t-tops and a 5.7. Was crushed to learn over the years that GM only offered the 5.7 with factory t-tops only for the 1989 model year, the same year no more Digital Dash's Search has also been hard to find a clean car with a fully functioning dash with all the LCD's functioning and on. You've never had to do anything with yours?
Reply 0
Subscribe
