Speedo Key Delete???
Subscribe
May 5, 2002 | 09:47 PM
more RPO codes :
E9Z : SPEEDOMETER KEY (DELETE)
can someone please clarify?
Reply 0
May 6, 2002 | 09:56 AM
Yeah somebody must know, I have the same. Anybody???
Reply 0
May 6, 2002 | 02:15 PM
my first guess was the key that says Mph/Kmph onthe speedo, but i have that, so that theory didnt really work.
Reply 0
May 9, 2002 | 04:16 PM
My theory is that we are not meant to know what this code means.... further that no one knows what it means and it is to remain a "great RPO mystery".
My best guess is that if you need Kilometers you got a "speedo key" and if you needed Miles they "deleted" it.
Reply 0
May 10, 2002 | 09:20 PM
Would be a good guess but I have KM/h & the speedo key (delete); your theory that we weren't meant to know is more accurate.
Reply 0
May 10, 2002 | 11:46 PM
Well there as many speedo key deletes as there are rear end gears, and I'd guess that no matter what you got a speedo delete because for one reason or another your car has what ever gears it has because of it's drive train options....I'm not making sense am I Let me think of a better way to word that and I'll be back
Reply 0
May 15, 2002 | 12:13 AM
i could be wrong but i think it has to do with mph on one side of the speedo and kph on the other. cars without this rpo would have a needle on the kph side also ive had it both ways one my two 84 z's
Reply 0
May 15, 2002 | 08:19 AM
You have what is known as the double-pointer speedometer. 1984 was the last year it was used, and I'm pretty sure the mysterious E9Z doesn't have anything to do with the ol' "double pointer".
Reply 0
May 16, 2002 | 03:24 PM
I have a E9Z as well. I also have a E5Z: Speedometer adapter (delete).....and I was curious as heck as to what these were too?? My speedo is labeled with both mph and kmh
**EDIT**
After doing a little search around the board I found another "hypothesis" as to what the heck this could be. For example my car came with a variety of pkgs.
WW4: Appearance PKG, Aero #4
W62: Ornamentation, Aero PKG
W68: Merchandised PKG, Firebird, Sport Appearance
1SB: Option Package 02
There are couple others scattered on my build sheet. Now I know that some of these are external, and some are like floor mats and etc. But this seems to make sense:
If for example you ordered your car with a certain pacakage the affected instrumentation, or was related in anyway....you would be able to save money by deleting certain options. My car only has a 120 mph speedometer. Perhaps anyone with a E5Z & E9Z does not have a 140 mph speedo??!! How does this theory hold up....and hopefully it made sense.
Reply 0
May 16, 2002 | 06:04 PM
i have this mysterious delete thing in the 84 Z and its 85 mph with Kmp and MPH double speedo
Reply 0
May 17, 2002 | 02:14 PM
I've been giving this some thought. Maybe the speedo's key(way) was deleted when GM switched over to the electronically controlled speedometer (ie not cable operated)???
Reply 0
May 17, 2002 | 02:41 PM
That was not until MUCh later. I know I saw some 84's with the option and they did not have electric speedometers
Tom
Reply 0
May 18, 2002 | 12:51 AM
I have both the E5Z and the E9Z my car has the 145 speedo, which is cable not electric. I also have an E7Z which comes up as not in the database on the decoder
I also have 4 different codes 6ZW,7ZW,8NL,9NL they all come up as "spring, computer selected ......." for each wheel, but what exacly is this???
Reply 0
May 18, 2002 | 11:39 AM
Quote:
Based on options ordered and the way the car was built, the computer selected the best springs for the option build combination.
Reply 0
May 18, 2002 | 12:21 PM
i have 84 S/E with:
E5Z : SPEEDOMETER ADAPTER (DELETE)
E6E : SLEEVE, SPEEDOMETER GEAR
it has normal 85 mph non kpm speedo, IE not a double pointer like is in the maro with same RPO code...
Reply 0
May 18, 2002 | 01:38 PM
thanks scott, thats kinda what I figured on the sping codes but wasnt sure.
Reply 0
Subscribe
