Regular 88 Firebird with 350?
I own a 88' Firebird 350 with the 700r4. It isn't a formula but has the hood with the rise in it. I only thought they put these options on the formula.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Chances are, you have a formula, that someone changed the rear hatch if you do NOT have the areo wing. A Formula can be identified by the RPO sheet with a W66...
Engines:
87-88
V6 & V8 LO3 - Firebird
LO3, LB9 & L98 - Formula & Trans AM.
LB9 & L98 GTA
btw, in 89+ I believe the T/A was only available with a TPI engine.
LB9 & L98 - Trans AM. & GTA
the GTA was std with the L98 but was optional with the LB9 (5.0)
Engines:
87-88
LB9 & L98 GTA
theshackle
Mar 5, 2017 06:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
