DOHC on a V-8?
Car: 1984 Z-28
Engine: 350(bored 0.060)
Transmission: Probuilt TH700-r4 tranny with the w
Axle/Gears: 10 bolt 7.5" posi 3.42
DOHC on a V-8?
Does anybody know if there ever was a 350 engine made with DOHC.
(Dual overhead cams for the guys that hate imports
If not, will the chassis of a 1984 V-6 model Firebird hold up to a 454?
)If not, will the chassis of a 1984 V-6 model Firebird hold up to a 454?
Car: 89 Formula
Transmission: TH 700R4
ZR1 count? 5.7 DOHC 32 valve 388-405hp. Of course that was totally different from a SBC.
Many years back I read an article in a Hot Rod mag
about this comapny that were developing 4 vlave heads for the SBC. I think they probably cost a fortune- never did hear much about them after that.
Car: 1984 Z-28
Thanks for the input. I just found it on a 1995 ZR-1. Exactly how diffrerent is the engine as far as setting it up on a F-body
Car: Death Mobile
Engine: 666 c.i.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you're real lucky, you might find an LT5 crate motor for $12,000. Don't forget that you'll need the ZR1-specific ZF6 transmission (longer input shaft than other ZFs), and a TON of custom fabrication to make it fit.
Don't bother. I looked into this swap and came as close as you oculd get to calling and ordering the engine and tranny. You can get an LT5/ZF6 and all of the stuff for the swap for around $10K but it would require a totally custom exhaust and other custom fab as already mentioned. If you do it though, get the later 4 bolt 405HP LT5
FiReBReTHa
Aftermarket Product Review
Mar 11, 2001 08:02 AM
