whats up with that????
I was looking at the tech data on this site and the only 350 that it lists for any year is an L98... I know this isn't true... so what i'm asking is:
"What 350's were available in the Z28's in 1989?"
I'm considering buying one and the guy told my dad (they work together) that it was a 350 but dad said that it has a breather like on a carb or on TBI... so what is this??? possibly???
and what is the hp rating on the motors...
Sorry to ask so much
thanks a bundle
Cody
thanks a bundle
Cody
Re: whats up with that????
I thought all Z28's had TPI motors in them anyways, so if it looks like a carb then it can't be original.
~Tim
well did any z's come with 305's??? tbi maybe????
could that be it... or is it a 350 that someone has converted to carb???
cuz that would suit me just fine... i'd kinda rather have a 4 bbl anyway....
and what went with the 350 TBI, what did it come in????
thanks a bundle...
Cody
thanks a bundle...
Cody
Car: C1500
All thirdgen's that came stock with 350's will be TPI and will have auto trannys. They will also have L98 on the RPO sticker and the 8'th digit of the VIN number will be "8".
Maybe this car has been converterd to carb. You will probably be best off checking the engine casting numbers on the block to make sure it's a 350 in it.
The last 3 numbers in the casting number is on the side of the block on each side under the heads. '87 to '92 305 blocks have 627 on them in the place. I'm not sure what the 350 blocks have. You can look for these numbers on www.mortec.com
um
305..Z28.. 1982/83.. lets not forget the illfamed Crossfire Injection... i know some don't consider it TBI, but i do. maybe the guy is thinkin of that? my .02 cents
Re: um
Originally posted by dbarker02
lets not forget the illfamed Crossfire Injection...i know some consider it TBI, but i dont.
Wasn't the TBI LO3 305 the "base motor" on the Z28 and optional on RS - although it seems most Z28s got the 205 hp TPI 305. I remember reading that somewhere but I have never seen a Z28 with TBI (excluding Cross-Fire).
