which was the fastest 3rd gen Produced?
Old Sep 2, 2002 | 09:24 PM
Ksnoop20's Avatar
Hey everyone I'm new hear and interested in buying a 82-92 camaro. Do u know which year and model was the fastest? Or maybe even the 2nd and 3rd fastest years and models? thanks guys in advance for the help:lala:
Old Sep 2, 2002 | 09:33 PM
theCure's Avatar
Car: Looking
hey and welcome to the boards. i would say the 1LE camaro's are the fastest i think, but i would say get you an 87-90 Iroc with a 350 tpi/ auto or 305 tpi/ 5-speed or the 91-92 z28 350 tpi/ auto or 305 tpi/ 5-speed those are probably gonna be your fastest for less money
Old Sep 2, 2002 | 09:39 PM
GTATransAM's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
Fastest third gen, or just camaro, cause i assume its the 1989 Turbo Trans AM 20th Anniversary. Buick V6 turbo engine, GM rated it at 301HP, but i hear it was under-rated, so i dont know for sure.
Old Sep 2, 2002 | 09:45 PM
Ksnoop20's Avatar
Are the autos as fast as the 5 speeds?
Old Sep 2, 2002 | 11:04 PM
TTA155's Avatar
Fastest third gen car IS the 1989 Turbo Trans Am GTA no doubt about it.
Fastest third gen Camaro? I don't have a clue.
-Shawn
Old Sep 3, 2002 | 01:11 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Fastest special edition Camaro would be the 1LE IROC-Z's and Z28's. Fastest regular production would be the 87-90 IROC 350's and 91-92 Z28 350's. Yes the LB9 5-Speed G92's are quick, but they are not as fast as L98's Auto's and do not have the same potential either, but they would be up there too. The fastest LB9 Auto I think would be the 85's.
Old Sep 3, 2002 | 01:54 AM
SHO350's Avatar
Car: 1991 Trans Am
Why would a 1LE Camaro be any faster than a Camaro with the G92 option? Wasn't the 1LE option simply only brakes and suspension?
90-92 Speed Density TPI Camaros are most likely the fastest stock 3rd gen Camaro.
Old Sep 3, 2002 | 07:18 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
1LEs weighed slightly less due to no air conditioning and sparce interior options. That could account for minimal improvements in speed.
Old Sep 3, 2002 | 09:06 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Wouldn't the fastest 3rd gen Firebird be one of the 92 Firehawks with the aluminum 383 (cammed, t-rammed with a full exhaust setup), zf 6 speed tranny and dana 9" rear with 3.42 gears?
Just thinking out loud.
Old Sep 3, 2002 | 11:06 AM
92GTA's Avatar
Nope, I think the TTA is still a little faster than a Firehawk.
Also FYI, 'Hawk #026 did not have a T-Ram setup, it has an LT1 style intake instead.
Old Sep 3, 2002 | 11:41 AM
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Wouldn't the aluminum driveshaft account for a bit of it as well?
Old Sep 3, 2002 | 03:50 PM
The T/A way's Avatar
The fastest third gen period was the 1992 Firehawk.
1989 Turbo GTA ran a best of 13.5 in the quarter at 101mph. It had 0-60 times at 4.6
1992 Firehawk had a best quarter mile run at 13.2 at 107mph. It also had a 0-60 time of 4-6.
I don't believe there was a Camaro that could come close to these times so the '92 Firehawk would be the fastest 3rd gen. Of course it had a base price of $39,000 and the competition package was almost another $10,000.:hail:
Old Sep 3, 2002 | 09:50 PM
87350IROC's Avatar
Car: 87' IROC
Firehawks would be the fastest, then TTAs, then 1LE 350s, then L98 cars, then 305s. Chances are you are not gonna get your hands on a Firehawk, TTA, or 1LE, so that leaves the L98 cars. L98 is the 350 cubic inch engine. You could only get the 350 with an auto tranny. So now lets break down the L98 cars. Now, 91 and 92 350s are the most powerful however they are hard to find, not many were produced, at least not to many Z28s, don't know about Firbirds and T/As though. You also have to look at the rear end gears and posi. There were options on rear gear ratios, and posi or not. The first year for the 350 was 87' all these cars have the 3.27 gears with posi. 88' to 92' were optional. Also look on the tech data on this site for hp and trq ratings for each year.
Old Sep 3, 2002 | 10:32 PM
MdFormula350's Avatar
i agree with 87350IROC...
Old Sep 3, 2002 | 10:58 PM
70Firebird's Avatar
My new TTA
My TTA has been chipped and performance exhaust/minor intake mods. For a total of $600 (Mods) it will run 13 sec flat on 1/4. My best friend who owns a 454 LS6 Chevelle told me that the TTA "is so quick...it should be illegal "
1.) The TTA is a "actual production car" with its 1555 units sold. The Firehawk is not a production car.
2.) The TTA with the Turbo V-6 engine can be modified to run into the low 11s with a couple of hundred bucks and turbo boost mods. Can't say that about the Firehawk.
Pics:
http://photos.yahoo.com/bc/dmayans77...Photos&.view=t
Old Sep 3, 2002 | 11:09 PM
Administrator
If that 25th Anniversary Camaro was produced it would've been the fastest.
Old Sep 3, 2002 | 11:11 PM
92GTA's Avatar
70Firebird, Sorry but I believe you are wrong on the "production car" portion.
How can you possibly say that the TTA is production and that the Firehawk is not!
TTA: had of course it's own RPO code and could be ordered built as a TTA. Car built by GM and engine installed by PAS.
Firehawk: Also had it's own RPO code and could be ordered built as a Firehawk. Car built by GM and engine installed by SLP.
What's the difference? Both cars were sent to other companies other than GM to be completed so as fas as I am concerned, if there is an RPO code for it then it is "production", if not, THEN it is aftermarket.
Old Sep 4, 2002 | 12:00 AM
70Firebird's Avatar
92GTA Come on...don't stretch it. You know for a car to be considered a production run...it must have at least 1000-1500 cars produced. A "specialty" car to only have 27 cars "officially" and 25 actually,,, to be considered a production car is really pushing the envelope.
In that same arguement you could make a case that Pontiac should have outsourced to a 3rd company and build 25 + TTAs and install the $1000 dollars worth of upgrades required to get the TTA into the 11s...then we could call it the Super Duper TTA
I guess the pros at Car and Driver were wrong when they stated the TTA AS the quickest Trans Am ever (0-60 4.6 sec 1/4 mile at 13.4 stock)? With all the research material available to their car pro staff they must have missed something or fell asleep before they saw the Firehawk article.
Old Sep 4, 2002 | 12:04 AM
92GTA's Avatar
Well I guess you got me there because when I typed that post I wasn't even thinking about the # of vehicles that has to made for a model to be considered "Production". I guess if I was going to try and be technical I should have thought about that
Technically the TTA IS the fastest production Trans Am because the Firehawk if a Formula
Old Sep 4, 2002 | 11:48 AM
cg91ta's Avatar
As a side note, #26 is now for sale:
http://adcache.collectorcartraderonl...8/32154778.htm
Now if I only had money....
Old Sep 4, 2002 | 12:37 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Re: My new TTA
1550 TTA's and 5 piolit cars
TTA's are the fastest Trans Am to come from the factory ever as far as I know.
Kat
Old Sep 4, 2002 | 01:31 PM
70Firebird's Avatar
We both have good points:
Actually 1 of the 25 Firehawks made in the 1992 model year was a Trans Am Convert.
Let's say that the 2 cars were produced with slightly different "spirit" or "motivation" as Pontiac Motor Divisision was concerned. It could be said that the TTA was created in the "spirit" of a production car being in the minds of the Pontiac top brass. Remember that Pontiac has a tendency to borrow from other car manf technologies. i.e. use of Chevy 305, 350, Olds 403, and Buicks Turbo-V6. Thus would explain why PAS was contracted to make this Buick engine fit within the narrower engine bay (compared to wider engine bay of the GN/GNX) Pontiac heads/headers and other mods. I would bet the kitchen sink that Pontiac held the TTA in higher esteem based on a number of reasons... 1.) 1555 production number=more sales=$$$ 2.) Pace Car for 73rd Indianapolis 500 Race Honors 3.) 20th Annv Commemorative model.
The 92 Firehawk on the other hand can be seen as leaning more to the "concept car" camp. The engine was way ahead of it's time and sported LT-1 "ish" engine parts technology to a degree. Remember that the LT-1 was only available in Corvette for the 1992 production year and 92 F-Body was TPI. When I think of the marvelous Firehawk...I think of the mission statement of such contempories as Saleen, Legenfelter, Copo, Shelby.... Just an opinion.
Old Sep 6, 2002 | 10:05 AM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
I think an Iron Duke 3rd Gen falling off the edge of Mt. Everest would probably be the fastest......Man wouldn't that be a rush!!! The terminal volocity would be outragiously fast. Oh man, what am I thinking here? NO Camaro,..not even an Iron Duke should ever fall to that kinda fate. I apologize for my poor 3rd Gen humor. Back to the topic, TTA all the way. More production #'s, and endless potential.:hail:
Old Sep 6, 2002 | 10:12 AM
92GTA's Avatar
70Firebird, well technically the #027 Trans Am 'vert is NOT a real Firehawk because it does not have RPO code B4U. It's just a Firehawk clone made by SLP for some good 'ol boy with too much money so there
Old Sep 6, 2002 | 01:59 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Come on now guys, First he asked about a Camaro by name. He also sounds like he has little or no experience with these cars, So here's how it goes. Top 3 Camaro's
90-92 L98 cars w/ 3.23 rear (G92)
87-89 L98 cars w/ 3.27 rear (G92)
90-92 LB9 cars w. 3.42 rear (G92)
However if you are new to Camaro's I suggest you start with an early generation (83-85) L69 (H.O. 305) car (preferably stick). These cars will get you into the same style and cost far less, plus it will get you used to some of the power before jumping in over your head.
Later, Garrett
Old Sep 7, 2002 | 03:17 PM
bigals87z28's Avatar
Car: Check The Sig
did firehawks really have 383's? i was always under the assuption of the TTA beein the fastest f-body ever, faster then a 4th gen... stock....but i dont know a lot about firehawks.... they are so rare... thank *** slp did something with our cars before they want all 4th gen.
Old Sep 7, 2002 | 03:20 PM
92GTA's Avatar
Only Firehawk #026 has a 383, then a couple others have a 366 and the rest are 350's. #026 only has a 383 though because SLP had a mechanical problem with it's original 366 so when they rebuilt it they stroked it because the owner wanted more power...
Old Apr 26, 2020 | 09:14 PM
MikeJR1991's Avatar
Car: 91 Camaro Z28/1LE & 91 SLP Firehawk
Engine: 350/5.7 L98 & 383/6.3 L98
Transmission: 4L60 Automatic & T-56 6 speed
Axle/Gears: G80/G92 3:42 & WS6 3:73
Re: which was the fastest 3rd gen Produced?
Later, Garrett
There were a very rare few 91-92 Z28/Formula 1/LE’s with the 5.7 that were special ordered with the 3.42 GU6 option. These were by far the quickest besides the Firehawk.
Old Apr 26, 2020 | 09:17 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
...if it has an RPO, its production. Both the PAS-converted Turbo TA and the SLP-converted Firehawks had RPO Codes.
Old Apr 26, 2020 | 09:32 PM
George Klass's Avatar
Car: 1989 Trans Am
18 year old thread, it's fun!!
Old Apr 26, 2020 | 09:34 PM
Drew's Avatar
18 years later, I'm not sure he still cares.
Old Apr 26, 2020 | 09:36 PM
Big&BadGTA's Avatar
Some will hold a grudge...
Old Apr 26, 2020 | 09:46 PM
Drew's Avatar
The OP didn't own a thirdgen, he was window shopping. He hasn't logged in since a couple weeks after posting this thread, and he only ever posted the two questions in this thread.
The thread has long since done it's job, but certain people just can't exercise the self control to leave sleeping threads lie.
Old Apr 26, 2020 | 09:55 PM
Big&BadGTA's Avatar
Ahhh..... I didn't even look at the date when I first replied
ex-x-fire
Jan 12, 2024 01:58 PM
bjpotter
Jan 22, 2019 12:27 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
