Gold Rims
Old Oct 29, 2002 | 01:21 PM
Camaro89's Avatar
Gold Rims
What year camaros (IROCS) had gold 16" aluminum rims?
Old Oct 29, 2002 | 02:07 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
I know 88 was the only year that IROCS had 15 inch rims and were gold in color. Do you have a pic of the wheel?
Old Oct 29, 2002 | 02:30 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
If these are the ones you are talking about,they were available from 1985-1987.
Old Oct 29, 2002 | 02:32 PM
Camaro89's Avatar
The rims above this post are the ones I am talking about. Were they available as an option for a 1985 IROCZ L69 5 speed or just the non-IROCZ Z28s?
Old Oct 29, 2002 | 02:38 PM
MDv6man's Avatar
Car: 1983, 1986
If they're 16 inch, they are IROC exclusive (85-87).
Old Oct 29, 2002 | 02:44 PM
Camaro89's Avatar
Would there be an RPO code that would distinguish between 16" Gold Aluminum Rims and 16" Silver Aluminum Rims?
Old Oct 29, 2002 | 02:49 PM
MDv6man's Avatar
Car: 1983, 1986
I don't think an RPO would designate color (it doesn't for heritage stripes) -- I think color depends on the vehicle color and decal color
Old Oct 29, 2002 | 05:36 PM
kizz's Avatar
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
there should be wheel color RPO. at least there was in the earlier third gen, for trans am's and firebirds; that I know for sure. yours might be different, depending on what color the gold was for your year, or it might not be there at all. but if it's there, it should be 2 numbers followed by a P, like 55P, 87P, 13P, 40P, etc.
the 2 cars below (middle & right) both have 55P (gold wheel RPO)
the grey car below has 84P (grey wheel RPO)
Old Oct 29, 2002 | 08:49 PM
David M's Avatar
Car: '84 Z28
Engine: L69
The gold wheel code is either 88P or 92P.
Old Oct 29, 2002 | 09:40 PM
extreme3rdgens's Avatar
N96 code on one of my 87 Iroc-Z['s is for the 16X8 aluminum wheels, code 15P is for wheel color silver metallic. I have another iroc with factory Gold 16 inch wheels and can check the option code tomarrow if needed. Check out the picture of my 86 Iroc-Z with factory Gold wheels.
Extreme
Old Oct 30, 2002 | 09:57 AM
Camaro89's Avatar
In the RPO codes for the car, I found the RPO code 88P. However, the decoder on thirdgen.org didn't have it in its database. How do you know that 88P is the RPO code for gold wheen color?
Old Oct 30, 2002 | 11:13 AM
I just ran all of the option codes from my 86 Iroc-Z with gold wheels. The car has code 88P and the decoder dosen't have this code. All my other trim color codes are in the data base. 88A is the code for the accent stripe in gold so 88P may just be the code for the gold wheel accent, 15P is the silver wheel accent. So 88= Gold accent and P= Wheel?
Extreme
Old Oct 30, 2002 | 09:55 PM
David M's Avatar
Car: '84 Z28
Engine: L69
I've looked at many IROC's & Z28's over the years and have taken alot of notes. 88P seemed to be used for the 16in. gold wheels and 92P used for 15in. gold wheels on the Z28's.
Old Oct 31, 2002 | 07:08 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The gold package was available on IROC's from 85-90, not 85-87. The style of the wheel pictured was available in gold from 85-87, and was available on the newly restyled rim from 88-90.
Old Oct 31, 2002 | 07:44 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
maybe that helps?
10 Artic White
11_White
12_Silver Metallic
13_Secondary Exterior color (Silver Metallic)
16_Silver
19_Black (Interior Color)
23_Bright Blue Metallic (87 only) (Primary color)
23_Medium Maui Blue Metallic (88-91) (Primary Color)
24_Bright Blue Metallic (Exterior Color)
28 Black Sapphire Metallic (Exterior)
37_Dark Bright Teal Metallic (Exterior)
40_White (Primary Color)
41_Black (Primary Color)
45 Medium Green Metallic (Exterior Color)
51 Yellow Gold (87 & 88) (Primary)
52_Jamaica Yellow (92 Only) (Exterior Color)
52_Gold Metallic (Wheel Color)
60 Champagne Gold Metallic_
62_Lt Saddle / Medium Lt Saddle (Interior Color)
63 Medium Orange Metallic (Exterior Color)
66_Beechwood (Interior Color)
68 Dark Russet Mettalic
72_Dark Carmine (Interior Color)
74_Flame Red Metallic (Primary color)
75_Brilliant Red Metallic (Primary color)
81_Bright Red (Primary)
82_Med - Dark Gray (Interior)
82_Med - Rosewood Metallic (Extreior)
84_Gunmetal Metallic
85_Brilliant red
87_Gunmetal Metallic
98_Bright Blue Metallic (Primary Color)
From there the 3rd digit is what the application is:
A= Body Accent Stripe
B= Cloth Interior Trim
C= Cloth Interior Trim
D= Cloth Interior Trim
E= Cloth Interior Trim
F= Covering Floor Mat, Color
G= Cloth Interior Trim
H= Cloth Interior Trim
I= Interior Trim
J= Cloth Interior Trim
K= ?
L= lower (Secondary) Paint
M= ?
N= Interior Trim Combination_
O= ?
P= Wheel Color
Q= Molding Color
R= ?
S= ?
T= T-Top Color
U= Upper (Primary) Paint
V= All Vinyl interior Trim
W= All Vinyl interior Trim
X= ?
Y= All Vinyl interior Trim
Z= All Vinyl interior Trim
1= Interior Trim
2= Leather with Articulating Seats
3= Leather
4= Leather
5= Leather
6= Leather
7= ?
8= Cloth Interior Trim
9= Seat Belts
Old Oct 31, 2002 | 10:19 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
What did these look like? Anyone have pics?
Old Oct 31, 2002 | 10:26 AM
MDv6man's Avatar
Car: 1983, 1986
Bikertrashdude is the guy I met at one of the MD get togethers this past summer. He had the 15 inch gold rims on his car. I'll check the past threads and see if his wheels are in a pic.
Old Oct 31, 2002 | 01:31 PM
BikertrashDude's Avatar
yea i got 15" gold rims on the IROC. 88 was the only year that the IROCs had 15" (and i got stuck with gold ones)
car is black with gold "IROC" badges all around, the pinstripes around the car are gold too, took those off when i bought the car, it was too 80's for me.
the rims are your standard 15"x7" Z-28 rims but all gold (well yellow) I hate them. They are coming off this week.
I'll try and take a pic this weekend of the car, before i put the new (to me) rims on.
Old Nov 4, 2002 | 10:22 PM
Abubaca's Avatar
My buddy had a burgandy 88 with gold Iroc 15's.
Here's my 89.
Abubaca's Avatar
oops.
Old Nov 4, 2002 | 10:23 PM
Abubaca's Avatar
...and another
Old Nov 4, 2002 | 10:26 PM
Jim's Avatar
Jim
Car: 85 Camaro
here are your rpo's guys
88A STRIPE COLOR, ACCENT, TWO TONE, GOLD/BLACK (91)
88P Wheel Color -- Gold Metallic
Old Apr 22, 2023 | 11:27 PM
Carbon_Summit's Avatar
Re: Gold Rims
I know this is an old thread!!!
I recently bought a 1986 IROC that has on the RPO sticker 88A and 88P.
From reading this thread I'm gathering that these mean:
88A : STRIPE COLOR, ACCENT, TWO TONE, GOLD/BLACK (91)
88P : NOT FOUND - Many say it means 16" Wheel Color -- Gold Metallic
My wheels look silver to me which I found odd, and why I ended up finding this thread searching for an answer.
Have my rims faded or did someone change them? Or does 88P not really mean gold wheels?
Old Apr 23, 2023 | 02:33 AM
JT's Avatar
JT
Community Administrator
Re: Gold Rims
88P is for the gold wheels. 88A is for the gold graphics. The wheels are supposed to match the graphics color (silver or gold). 86P would be silver wheels and 86A would be the silver graphics.
Old Apr 23, 2023 | 10:16 AM
Re: Gold Rims
After looking online at other black and gold IROCs the PO must have changed the wheels to the sliver ones. But to be honest I'm kind of thinking the gold has a lot of gold on it, maybe I'll just live with the ones I have. Debating on adding some gold to them to make them "match" but that might end up looking crappy too.
Old Apr 23, 2023 | 12:27 PM
scottmoyer's Avatar
Re: Gold Rims
The black and gold IROC-Zs are classic, but the wheels need to match the emblems and graphics. If you think the exterior gold is too much, you'll need to replace the graphics and emblems with silver for the car to look correct. Or, you could do what a lot of people have done and remove the graphics and just replace the emblems to silver ones as the factory ones are probably in rough shape these days anyway.
The issue with the exterior being accented in silver is that it won't look right when you have the tan interior. The easiest option will be to get these wheels painted correctly to match the tan, or buy new/aftermarket wheels.
Old Apr 23, 2023 | 02:28 PM
Re: Gold Rims
I don't disagree that the wheels I have in reality don't match the rest of the car...but I think you might be a little more militant about "having to have gold wheels" than I am.
If I did aftermarket wheels that were all brushed aluminum or chrome I don't think anyone would think twice about it. I'm guessing 99% of the general public won't notice that they don't match. Don't match in our eyes because we know what they should be. But again I don't disagree they are wrong, that gut feeling was why I was searching on here to for sure what the RPOs on my car meant.
Honestly the bluish cheap Walmart tint on the side windows is a lot bigger eyesore in my mind! Getting that all replaced and the hatch tinted soon enough. But in the big picture my plan is to drive the car for the summer and decide if its a keeper or not and then I'll worry about making some changes. I had a Gen 2 T/A Y82 when I was younger so I do like the black and gold combo and the more I look at the pics of your car vs mine the more I'm warming up to getting some gold ones/refinishing these/etc.
Old Apr 24, 2023 | 10:48 AM
Abubaca's Avatar
Re: Gold Rims
I may be biased in that I owned my red/gold 89 for 20 years, but I think it'd look a little off with some gold and some silver. Silver can go with chrome, black, other colors etc. etc. -for example the red decals still got silver wheels. The gold wheels though, kinda needs to go with gold, at least in my opinion. ....now to Scott's point about the interior, I'd have no issues with the exterior being silver, but having the tan interior. Many many cars offer that. BUT to each their own of course.
Old Apr 24, 2023 | 10:50 AM
Abubaca's Avatar
Re: Gold Rims
I'd also like to point out that Scott and I have both participated in this entire thread, going back over 20 years. That's kinda cool. Love this group!
Old Apr 27, 2023 | 08:12 AM
scottmoyer's Avatar
Re: Gold Rims
Chris, I wonder where that 20 year member icon is!! JT???
Old May 6, 2023 | 08:07 PM
Re: Gold Rims
I have to concede the silver wheels on my car just don't look right. Maybe I was trying to lie to myself to save some money???
Working on getting it running right and fixing a lot of little things right now. Got the car retinted this week, and this coming week its going in for new exhaust from the exhaust manifolds back. I went with Magnaflow to replace the clapped out Flowmaster muffler at the end of a lot of rusty old parts... anyway point relevant to this thread is gold rims are a must. Just want to get a few other things done first but I'm laying in wait for some factory ones to surface.
Old May 6, 2023 | 08:08 PM
Re: Gold Rims
Or should a guy get the silver ones refinished gold?
Old May 10, 2023 | 02:42 PM
Abubaca's Avatar
Re: Gold Rims
I think it depends on budget and just how nice you're planning on getting the car. With a little patience, you could probably sell the silver and find some gold ones for no money loss. ....refinishing will cost ya, but they'll be more less perfect. ...depending on condition, you can always refinish yourself too. I'd done a few sets over the years. The paint is easy if you have some patience, it's the machined faces that can be tough. You can always polish them (which looks awesome btw) but if you want the OEM machined look and they have some damage, you'll probably want to have a pro refinish.
Pretty sure Hawk's sells factory refinished too, if you haven't looked yet.
ChelseaHere
Wheels and Tires
Feb 4, 2019 09:15 AM
91DropTopTA
Jan 13, 2006 08:23 PM
trans_am_ta_84
Mar 24, 2003 03:18 PM
