87 1le Iroc?
Old Dec 18, 2002 | 10:49 PM
92RS87Z_Driver's Avatar
Car: 92RS
Engine: 305tbi
87 1le Iroc?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1875005110
I did a search and Im sure they exsist, but how rare is a 87 1LE IROC? Is there a way to check if it is a 1le by the vin # or my the rpo code only? Any help is appreciated
Old Dec 18, 2002 | 11:22 PM
Benny's Avatar
That car is a pile o S***
Old Dec 18, 2002 | 11:23 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I'd say that car is pretty rare. Especially considering that there were never any made.
1LE's started in 88. If its an 87, its not what its advertised as.
Old Dec 19, 2002 | 08:29 AM
Z28DJP1987's Avatar
A very RARE CAR. If you can find one, get it. RARE RARE RARE.
Old Dec 19, 2002 | 10:04 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
1 of none.
Old Dec 19, 2002 | 10:17 AM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
No such thing as an 87 1LE, the car is bogus
Old Dec 19, 2002 | 12:07 PM
MdFormula350's Avatar
missing alot of key stuff!!
Old Dec 19, 2002 | 12:38 PM
BikertrashDude's Avatar
i saw that before
I think some people put in just about anything to get a "hit" on their auction.
why are they selling? hmm,I tore this car down and guess what the frame is shot!!!! lets get rid of it.........
biker
Old Dec 19, 2002 | 07:49 PM
smallwood's Avatar
If, just suppose, this guy knew he had an original 1LE and planned on hacking it up into a drag car, he should be shot.
Old Dec 20, 2002 | 08:11 AM
Jim85IROC's Avatar
If he had a 1LE, then yeah, but since there weren't any in 87 (and I'm sure he knew that), there's really no issue with that.
Old Dec 20, 2002 | 08:15 AM
Jim85IROC's Avatar
Thirdgen.org is definately a great place to be. Since you're from the Boston area, you might want to check out www.nethirdgen.org too. It's a non-tech thirdgen site that started off with mostly north east members (hence the name). There's a few Boston-area folks on there.
Old Dec 20, 2002 | 12:37 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
What does a true 1LE package consist of???
Old Dec 20, 2002 | 12:44 PM
92GTA's Avatar
Fuel tank: 10121026
Fuel sender unit (longer): 25094804
Fuel strainer (double screen): 25121120
Fuel Pump: 25116163
Aluminum driveshaft: 10085375
AC delete pulley: 10115875
Suspension:
Front strut: 22064153
Front sway bar (36mm): 14094344
Front sway bar bushing (36mm): 14094388
Front brace (frt end sheet metal radiator opening): 14039401
Front coil spring (code CDB): 14029396
Front steering knuckle LH: 18016737
Front steering knuckle RH:18016738
Rear lower control arm: 10164151
Rear lower control arm bushing: 10164152
Rear shock absorber: 22064149
Rear sway bar (24 mm): 10035033
Rear sway bar bushing (24 mm): 10037105
Rear coil spring (code NNL): 10018091
Brakes:
Master brake cylinder: 18014286
Master brake cylinder piston (secondary): 18006832
Proportioning valve (2nd design, 1.5 tube nut threads): 10136840
Proportioning valve (1st design, 1.0 tube nut threads): 14089496
Front caliper bolt: 14084051
Front caliper bracket: 18016034
Front caliper retaining clip: 10132842
Front caliper LH: 10132827
Front caliper RH: 10132828
Front caliper guide pin: 10140666
Front caliper anchor plate LH: 10132829
Front caliper anchor plate RLH: 10132830
Front caliper bolt washer: 14080254
Front caliper hose LH: 10113075
Front caliper hose RH: 10113076
Front brake hose to caliper bolt: 14047782
Front brake hose to caliper bolt washer: 14076180
Front rotor (w/ hub and studs): 18016035
Caliper bleeder cap: 14089150
Front caliper bleeder: 14071826
Front caliper piston: 10104482
Front brake caliper guide pin boot: 14067552
Front hub outer bearing: 457049
Front brake pads: 10104485
Rear caliper plate and bracket bolt: 10112649
Rear caliper guide pin bolt: 14067559
Rear caliper mount bolt: 10097602
Rear caliper housing w/ piston LH: 10132831
Rear caliper housing w/ piston RH: 10132832
Rear caliper guide pin: 14067560
Rear caliper anchor plate: 10112652
Rear brake caliper guide pin boot: 14067552
Rear brake hose: 17688596
Rear brake hose to caliper bolt: 14047782
Rear brake pipe bracket: 10097601
Rear brake hose to caliper bolt washer: 14076180
Rear disk brake mounting plate: 10080876
Rear rotor: 10087702
Rear caliper bleeder cap: 14089150
Rear caliper bleeder: 14081826
Rear caliper piston: 10112643
Rear caliper piston seal: 14067562
Rear brake pads: 10132836
Old Dec 20, 2002 | 12:53 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Thats alot of stuff that they came with...Now do IROCS (86 in particular) come with most of those or are they just specific to the 1LE??
Old Dec 20, 2002 | 02:23 PM
Drew's Avatar
I'll put it this way... the only part of the 1LE package that was 1LE only was the larger front brakes.
The front sway bar is the same as most later WS6 Firebirds.
The front springs are typical Z28/WS6/FE2 springs, same with the rear.
The aluminum shaft and spare were available seperately.
A/C delete was available seperately.
Etc...
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
