1987 Iroc body.. what to do?
Is that the same one that was on Ebay a little while ago???
GOOD LUCK!!!
It is NEVER any fun picking up on someone elses project. It would be A LOT cheaper to buy one that runs and just fix it up a little at a time.
Tom
GOOD LUCK!!!
Tom
This may sound odd .. but I would go out and purchase another Iroc around the same year as yours and build one car between the two. I am finding even using ebay that it costs a lot to purchase individual parts (just check out the price of GFX you will need).
Also, find someone near your home with the same type of vehicle. It always help to go have a look at their car when you are confused how to install something.
Good luck and take your time. I am looking at 3-4 years on mine.
Guest
Posts: n/a
I have an 87 Iroc that runs lol.
Yes it is the one on Ebay, I am IrocuBabe on ebay.
I am hoping to be able to get this one to look as nice as mine does. I know it will probably take a few years... of course seeing as how I have no life and only work 4 times a week it could take less.
Re: 1987 Iroc body.. what to do?
Originally posted by IrocUBabe
I purchased the shell of an 87 Iroc to rebuild as part of my trying to become a mechanic.
So my question to you guys is what should I put in it. Thisis my first attempt to restore a car.
What do you wanna do with it, though, Crystal? Trending Topics
Car: 1992 Z-28 Convertible
Engine: 305 LB9 TPI
Agreed, if you want to be a meck-can-ic as you say, start with a bare block 350, and build a 383 stroker. It will not be cheap, but at least you can say you did it. It would probably be less expensive to buy a crate 350, but how much fun is that
res·to·ra·tion n.
1. An act of restoring: damage too great for restoration.
An instance of restoring or of being restored: Restoration of the sculpture was expensive.
The state of being restored.
Something, such as a renovated building, that has been restored.
Restoration
As it applies to cars, a restoration would be to return the car to completely stock. Which in this case far too much of the original car is gone to truly restore it. You could find all original stock parts on various junkyard cars and rebuild it to how the factory built it, but technically the numbers won't match.
You could also rebuild the car with whatever parts you want and make the car anything you want, but it wouldn't really fall under restoration.
Restoration
Guest
Posts: n/a
Okay well then I don't plan on <b>RESTORING</b> it to what it was before, when I said restore I meant bringing it back to working condition, not factory condition. I think I've decided to make this car into a more of a race like car then a daily driver, so that is what I plan to do with it Tom
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
